Intake Holder - Help Cannot Remove Screw
- Nerdy
Re: Intake Holder - Help Cannot Remove Screw
25 Jul 2022 19:36One thing I haven't seen mentioned here yet, I have always found with these type of fixings using a flat ended drift or old socket extension give the head of the screw a good smack square on. This often release some of the tension on the threads and helps getting it out
PS: when I say a good smack common sense should prevail
Same, but I like to use a center punch when dealing with Philips/JIS screws - get it right in the middle of the X.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Irish Yobbo
25 Jul 2022 20:41
All good ideas, and if none work you can use vise grips on the head of the bolt, and if all else fails, an angle grinder to take the head off, then with the boot gone and better access, you should be able to get enough purchase on the remaining bolt to remove it.
Unless you're going for originality, consider switching to allen head bolts which don't strip easily. After 40+ years of use with a lot of people incorrectly using phillips-head screwdrivers on these JIS bolts, it's really common for these to be stripped. There are plenty of stores online selling stainless allen head bolt kits which are much better.
1981 KZ750 LTD
- slmjim+Z1BEBE
26 Jul 2022 04:47
Vampliers. Specialty screw extractor pliers. Sold individually or as a set. Also produced by the 'Engineer' brand. Anyone who appreciates quality tools exhibiting fine fit & finish will be happy with either.
www.amazon.com/Professional-Internationa...s%2Caps%2C148&sr=8-8
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
26 Jul 2022 06:56Completely agree however, the above measures suggested are aimed at relieving the hold the head has on the bolt, without doing this first getting a better grip on the bolt will simply increase the risk of breaking it off in situ. A lot of extraction tools are great for bolts that have been broken through overtightening and therefore aren't seized in (IMHO)Vampliers. Specialty screw extractor pliers. Sold individually or as a set. Also produced by the 'Engineer' brand. Anyone who appreciates quality tools exhibiting fine fit & finish will be happy with either.
Good Ridin'
slmjim & Z1BEBE
- Gdailey2112
- 82 KZ1100D1
10 Aug 2022 17:39
sorry not meaning to hijack this thread but how often should one change his intake boots? ty
1982 KZ1100D1
10 Aug 2022 17:44sorry not meaning to hijack this thread but how often should one change his intake boots? ty
Depends on storage conditions. Every 25 years or so, if using OEM boots, sounds about right.
The following user(s) said Thank You: Gdailey2112
- Kelly E
11 Aug 2022 08:57 - 11 Aug 2022 08:58
Vessel Impacta JIS screwdrivers are great. The impact driver is built into the screwdriver's handle.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
Last edit: 11 Aug 2022 08:58 by Kelly E.
- Kidkawie
- I bleed premix
12 Aug 2022 15:53Depends on how the bike was stored, maintained, etc. Mine are original, still good, soft with no cracks.sorry not meaning to hijack this thread but how often should one change his intake boots? ty
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Nerdy
12 Aug 2022 20:09Vessel Impacta JIS screwdrivers are great. The impact driver is built into the screwdriver's handle.
I have a set of those. They are quite nice, but I have never felt comfortable trying to use the impact function. The idea of hitting a screwdriver with a hammer makes me cringe, even if it's designed to be hit, so I switch to the purpose-built impact driver.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- Kelly E
13 Aug 2022 14:43
Well you should try it out sometime. They work great and can get in where the fat impact driver won't. They still work after two years of constant use.
1983 Honda CB 1100F
And more
1983 Honda CB 1100F
And more
13 Aug 2022 15:31
I use an Impacta, as needed, when rebuilding carburetors. For engine covers and carb boots, I think a real impact driver is more appropriate.
The following user(s) said Thank You: slmjim+Z1BEBE
- slmjim+Z1BEBE
14 Aug 2022 05:27Didn't know those existed. Another very useful fix for us tool junkies!Nessism post=872175I use an Impacta, as needed, when rebuilding carburetors. For engine covers and carb boots, I think a real impact driver is more appropriate.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
