KZ200 - kickstart only - won’t start
  • andrewlafkas
  • andrewlafkas's Avatar Topic Author
Re: KZ200 - kickstart only - won’t start
18 Apr 2022 16:49
#865708
This didn’t work, unfortunately.
If your mixture is too rich, starting fluid will make it even richer and it will not start.
Turn off the fuel and drain the carburetor bowl. Now will it fire with starter fluid?
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 Apr 2022 17:41 - 19 Apr 2022 04:07
#865714
Your connection to the coils from the battery is good.(i didn't check that connection yet)
Your spark plug's ground is good.
Your battery voltage is low though, but a kick start should fire it.
Do you still have the 11amp battery and is it fully charged?
81-KZ440-D2.
LIC, NY
Last edit: 19 Apr 2022 04:07 by F64.
  • ckahleer
  • ckahleer's Avatar
19 Apr 2022 07:42
#865745
It should of at least sputtered. It should at least sputter even without a carburetor.
My thoughts now are:
Compression very low.
Valve timing way off.
Spark timing way off.
1997 ZL600
94 KE100
82 KZ305
74 TC185
