KZ200 - kickstart only - won’t start
- andrewlafkas
16 Apr 2022 09:17 - 16 Apr 2022 09:42
Hey All
I own a 78 kz200. 17K kms.
I removed the starter over the winter turning it into more of a leaner café style ride with a kick start only (kicking myself now, pun intended).
The bike ran well before but needed a carb clean/ rebuild, new exhaust and a few minor things. Long story short, carb has been rebuilt. Fresh oil. Fresh gas. Fresh plug.
I have gas, air and a solid spark but the bike will not start. No sputter, nothing.
Where do I start? What am I missing?
Thank you in advance.
Last edit: 16 Apr 2022 09:42 by Street Fighter LTD.
Re: KZ200 - kickstart only - won’t start
16 Apr 2022 12:20
Has anything changed in the intake system? Such as getting rid of the airbox? If so, is the carb properly jetted for a pod air filter? And of course, is the floatbowl full of gas?
- andrewlafkas
16 Apr 2022 13:03
Thanks for your response.
Everything else is bone stock.
Stock air box.
Float bowl is full, yes.
Carb was set to factory setting.
Tried some starter fluid this morning and that didn’t work.
Stock air box.
16 Apr 2022 14:38
Did you change any of the brass parts? If so, did you use genuine factory parts, or aftermarket? Did you check the fuel level in the carb?
16 Apr 2022 15:58
Just out of interest, if you have everything else - have you checked compression & timing ?
- andrewlafkas
16 Apr 2022 19:45
I haven’t but I will now.
I just assumed both would be fine if the bike was running prior to. The two mechanical changes were only removing the starter and rebuilding the carb (which could have been done wrong, I suppose) Everything else was purely cosmetic and maintenance. (Brakes, shocks, forks etc)
- andrewlafkas
16 Apr 2022 19:47
In regards to the carb rebuilt kit I used the keyster carb kit. Your thoughts?
16 Apr 2022 21:16 - 16 Apr 2022 21:17
Keyster has a good reputation. The brass parts in these carbs do not generally need to be replaced.
I did not ask if the floatbowl was full. There is a specific fuel height that is required. If the fuel level is too high, the carb may flood. If it is way too low, the jets may not be able to pick up fuel. There is a fairly narrow sweet spot.
Last edit: 16 Apr 2022 21:17 by TexasKZ.
- ThatGPzGuy
17 Apr 2022 05:54
If nothing happened with starter fluid, I would suspect the issue is not fuel related. Are the plugs wet?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
17 Apr 2022 06:31
Do you have a long hill or some friends to push you to see if it will start or sputter or backfire ?
- JR
17 Apr 2022 07:49
With some carbs its easy to put the floats in upside down when reassembling.
- andrewlafkas
17 Apr 2022 08:31
Copy that. I will check the float bowl level.
