Which carbs are these? 1979 KZ1000 LTD
- Webbie1
Re: Which carbs are these? 1979 KZ1000 LTD
10 Dec 2021 05:41Here is a thread discussing a restoration I did on a set of those carbs...
www.kzrider.com/forum/3-carburetor/61501...s-b-vm-carbs?start=0
Man....I have to be honest. After reading all of that, I wonder if I should even invest the time and money to rebuild these VM26's or just move to something else like VM28's? I bought the intake boots on both sides of the airbox already for these VM26's (about $250 for all), but they also fit the VM28's which seem to be way more tunable and produce better power. Thoughts on that? Your article actually scared me off a bit on the VM26's Am I overreacting?
Warner
1979 KZ1000 LTD, 1982 KZ1000 LTD, 1990 Honda CBR1000F
10 Dec 2021 06:55
VM26's are fine. It's the pump on that version of carbs that's the problematic part. And most VM28's have a pump, so there is that.
The following user(s) said Thank You: Webbie1
- zed1015
10 Dec 2021 08:22
You can delete and blank off the sensor circuit ( triangular diaphragm ) on these VM26's and they will behave like normal 26's with the advantage of the accelerator pump.
- Webbie1
21 Dec 2021 18:49You can delete and blank off the sensor circuit ( triangular diaphragm ) on these VM26's and they will behave like normal 26's with the advantage of the accelerator pump.
Where can I get instructions on how to do this procedure?
Thanks!
Warner
22 Dec 2021 05:04In the thread that I linked earlier, it shows how to disable the 2nd diaphragm.
