CV 36 help
  • TexasKZ
  • TexasKZ's Avatar
Re: CV 36 help
26 Apr 2021 04:45
#847472
With the stock airbox and filter properly in place and a full exhaust system, even with no baffle, the factory jetting should be really close. Are you sure that the factory jets are in place, including the factory needles? I would be very wary of any jet kits except those from Dynojet, Factory Pro, Ivan’s, Dale Walker, or Keyster.
  • Peanuthead
  • Peanuthead's Avatar Topic Author
Re: CV 36 help
26 Apr 2021 08:35
#847486
I wish I had written down the jet sizes when I cleaned them last. As far as the needles go, they are K&L. I used them before on an old suzuki and didn't have a problem.
  • Peanuthead
Re: CV 36 help
30 Apr 2021 20:00
#847794
I torn down the carbs again, cleaned them (little bit off crap came out), verified what jets I had (88 for secondary & 65 for the primary), and installed the exhaust baffle tonight. She runs the smoothest ever, since 2011. Can't wait to take another test ride because I thing she's fixed.
  • TexasKZ
  • TexasKZ's Avatar
Re: CV 36 help
01 May 2021 20:45
#847856
Good deal. Do you have a good fuel filter installed? There may be more bits of crap on the way to your newly cleaned carbs.
  • Peanuthead
Re: CV 36 help
03 May 2021 10:25 - 03 May 2021 10:29
#847927
I do not have one for her. I've been debating on that for a while. Part of me wants to keep the screen on the peacock and the other wants to remove it and just have the inline filter.
Here's my Instagram account that has the videos of her first fire-up last year to the most recent fire-up with the baffle installed.
Last edit: 03 May 2021 10:29 by Peanuthead.
  • TexasKZ
  • TexasKZ's Avatar
Re: CV 36 help
03 May 2021 16:07
#847948
I would keep the screen on the fuel valve and add a Golan super mini to the fuel line.
Re: CV 36 help
03 May 2021 16:48
#847950
Exactly!  That's what I put on my KZ650.  It's made of metal and its internal screen can be easily cleaned so it will last forever.  Not cheap, but really nice!  Ed
  • Peanuthead
Re: CV 36 help
04 May 2021 03:19
#847965
I thought y'all ment $35 expensive but not $50 expensive (damn!). I just grabbed a wallet friendly $4 mini filter from Auto Zone. This week looks like crap (rain all week) so I won't be able to take a test ride.
  • TexasKZ
  • TexasKZ's Avatar
Re: CV 36 help
04 May 2021 06:46
#847976
Yes, they are pricy, but it will never need replacing and filters out much finer trash than the less expensive ones.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: CV 36 help
04 May 2021 07:26
#847980
Glad she's running better for you.
Most, if not all, I've read about carb kits, is to not use the needles in the kit, and stick with the stock needles.
This may be different for CV carbs though.
As long as she is running fine, then great.
A bit of tuning here and there for better performance may be possible.
I'm in a similar situation with the carb swap (VM24 to CVK32) on my KZ650.
She's running great, but I'm sure some fine tuning will help get her running even better.
Been a lot of rain here lately, and only have 200 kms on the KZ650 since sitting 5 years.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • Peanuthead
Re: CV 36 help
15 May 2021 05:30
#848459
On today's episode of "As we tune the carbs" I think my 440 is running too lean. I fired her up with the tank installed, new fuel line, fuel filter and clamps. She idles kinda smooth, pops slightly on decel, and still stumbles on acceleration. So for sh!ts and giggles I put my hand over the snot box holes and she PURRED LIKE A KITTEN! Her idle was perfect and while rolling the throttle (slowly and fast) there was no popping!
So now the question is:
1- Do I re-jet & to what?
2- Do I turn the pilot screws out more?
  • TexasKZ
  • TexasKZ's Avatar
Re: CV 36 help
15 May 2021 07:30
#848469
What exactly do you mean by snot box holes? If there are random holes in the air filter box, or there are factory holes that are supposed to have something connected to them that is not connected, then the mixture can be too lean. Some factory boxes have an intake silencer, sometimes referred to as a snorkel. If it is missing, you will have mixture problems.
