Carbs sending fuel into filter not cylinder
  • Bluerider
  • Bluerider's Avatar Topic Author
16 Mar 2020 15:55
#821024
Replaced all gaskets on the top end. Now when it fires up (no issues there) carbs 2 and 3 are not sending the fuel into the cylinder but into the pod filters. Put out two fires thus far. Is this more of a ring issue or a carb issue? 1978 KZ1000LTD. no mods but the pod filters and the frame.
  • baldy110
  • baldy110's Avatar
Re: Carbs sending fuel into filter not cylinder
16 Mar 2020 16:20
#821026
Check the float levels bet they are to high.
  • TexasKZ
  • TexasKZ's Avatar
16 Mar 2020 16:25
#821028
Yup. Should have been checked when the carbs were rejetted.
  • Bluerider
16 Mar 2020 16:34
#821030
Too high or stuck? Will pull them again later. Did rebuild them last year though. Set the carb height based on book with a micrometer.
  • TexasKZ
  • TexasKZ's Avatar
16 Mar 2020 16:36
#821031
Could be sticking.
  • Nessism
  • Nessism's Avatar
16 Mar 2020 17:32
#821035
Sticking likely. Hope you rejetted for the pods or you will be pulling the carbs again in the near future.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Mar 2020 20:26
#821038
Are the coils connected to the right cylinders?
  • calum
  • calum's Avatar
17 Mar 2020 00:55
#821044
To confirm that it's an issue with the floats you could just set the petcock to prime. If it doesn't overflow then the float height should be fine. Are 2 and 3 firing?
  • shrap66
  • shrap66's Avatar
17 Mar 2020 03:01
#821045
This just happened to me after doing a carb rebuild. I thought I did everything right. Ultrasonic cleaned. New O-Rings, gaskets, rejet etc.
When I started the bike fuel was flowing from the pods. All 4. The bike was running but something was very wrong.
Could not be a case of stuck valve if all 4.
I had installed the needles upside down. Stupid mistake.
Make sure you drain your oil as it will likely be contaminated with gas.
1979 KZ1000B3 LTD Glacier Green
  • jayrodoh
  • jayrodoh's Avatar
17 Mar 2020 05:46
#821049
calum wrote: To confirm that it's an issue with the floats you could just set the petcock to prime. If it doesn't overflow then the float height should be fine.
Good troubleshooting tip, if float levels are correct and needles are seating properly you should be able to leave a petcock on prime (or on for a manual one) without any leakage from carbs.
1982 KZ750-M1 CSR
  • baldy110
  • baldy110's Avatar
21 Mar 2020 11:49
#821312
Float height has nothing to do with float level. Float level is what you need, set the levels using the wet method as described in the manual.
The following user(s) said Thank You: Mikaw, calum
  • Mikaw
  • Mikaw's Avatar
21 Mar 2020 12:01
#821316
Not a true statement. Don’t trust the measurement method. It’s just to get you close. The only true float level is achieved by the wet method as Baldy110 states. Been there done it. Truly a PITA. COMPLETELY WORTH IT
