Carbs sending fuel into filter not cylinder
  • Bluerider
  • Bluerider's Avatar Topic Author
Re: Carbs sending fuel into filter not cylinder
27 Mar 2020 10:22
#821904
There is spark. the plug smells of fuel. Did the old school thumb over the plug hole and spun the motor over feels like the other cylinders. Going to go through with feeler gauges at a later date. Thank you
  • Mikaw
  • Mikaw's Avatar
27 Mar 2020 11:04
#821905
Swap the #3 plug into another known running cylinder and see if the problem follows the plug. If it does it’s a bad plug. If not the the plug is fouled. If plug fire in known good cylinder, possibly plug wire, try swapping out plug wire. These are cheep ways of test items
  • Bluerider
29 Mar 2020 09:38
#822118
The plugs have been moved around soo much I have no idea what one was the original. But the problem always stays at cyl 3. But did check the valve clearances. But I think this just opens another can of worms. The thinnest feeler I have is a .03. and I have 4 that are tighter than that. And 3 that are over the .1. and 1 is within spec at .06. I am working mm. But the bike starts and fires up just fine then the cyl 3 carb starts to leak. This is becoming such a PITA.
  • calum
  • calum's Avatar
29 Mar 2020 13:51 - 29 Mar 2020 13:56
#822132
The bike will start fine with those clearances, just won't run as well as it could. The valves with < 0.03mm clearance could be always open (almost certainly will be when the engine warms up). This may cause airflow back through the carbs on the compression and exhaust strokes. If it's enough airflow it will pull fuel out through the jets (on the compression stroke there will already be fuel mixed in with the air). This air and fuel will then end up in the air box/filter.
Is the intake valve on cylinder 3 one of the ones with no clearance?
Last edit: 29 Mar 2020 13:56 by calum. Reason: Corrected logical error
The following user(s) said Thank You: Mikaw, Bluerider
  • Mikaw
  • Mikaw's Avatar
29 Mar 2020 13:53 - 29 Mar 2020 15:18
#822133
[strike][/strike]You mentioned you swapped the plugs. Did you switch plug wires? Unfortunately any mechanical item can be a can of worms in and of itself. Take a deep breath and understand there are no shortcuts. These bikes are easy to work on, meaning physically things come aparts simply without a lot of stress. Basically once the tank is off you’ve done most of the hard work. Sounds like you should start at page one on the [strike]general maintenance[/strike] engine adjustment section of a FSM. Testing and checking timing, valve lash, float levels and such. Can’t start in the middle and have good results
I’ll send you a [strike]like[/strike] link to a FSM,
Last edit: 29 Mar 2020 15:18 by Mikaw.
The following user(s) said Thank You: Bluerider
  • Mikaw
  • Mikaw's Avatar
29 Mar 2020 13:55
#822135
  • Bluerider
29 Mar 2020 17:01
#822149
It currently has a 270a in it on the intake side and that puts it under .03. And a 220a in the exhaust putting that one over .1.
  • Bluerider
29 Mar 2020 17:09
#822150
I have it thanks. And deff not starting in the middle.
  • calum
  • calum's Avatar
29 Mar 2020 17:20
#822152
Quick test may be to swap the shims. You'll probably have too much clearance on the intake side (which should hopefully solve the problem as the valve will definitely be closed on the compression stroke and won't open too early on the exhaust stroke). The reduced clearance on the exhaust side may cause some smoke out of the exhaust but should be OK if you're just testing.
If swapping the shims solve the problem then start measuring and order some new ones ;)
  • hardrockminer
  • hardrockminer's Avatar
29 Mar 2020 17:27
#822153
You need to get your valve clearances right before looking at anything else. Otherwise you're just wasting time and energy. If you know you have some tight valves then why not fix them?
  • Mikaw
  • Mikaw's Avatar
29 Mar 2020 18:09
#822155
calum wrote: Quick test may be to swap the shims.
In order to “swap” shims you need at lease one extra. Do not rotate the engine without a shim in the bucket. Bad bad!
Please listen to the members here. All systems need to be operating correctly in order to get a good running machine. Fuel, spark, and compression. The only way to do that is to take the time and do it.
  • calum
  • calum's Avatar
30 Mar 2020 02:10
#822174
Mikaw wrote:
In order to “swap” shims you need at lease one extra..
Not if you pull both cams. But I agree, the clearances need to be sorted. If it was me though, I'd be too curious (impatient?) and would want to find out if this was the problem while waiting for the shims to arrive.
