Stripped carb boot screw
  • ERIK814
  • ERIK814's Avatar Topic Author
30 Jan 2019 18:51
#797941
Got three off no problem. Then the fourth slipped right as it started to turn and bam, stripped. There is a small amount of grip but then the screw starts to cam out. I don’t want to make it worse, so what next?
1981 KZ 440 LTD Belt Drive (Late Model)
Re: Stripped carb boot screw
30 Jan 2019 19:06 - 30 Jan 2019 19:07
#797943
It looks to me like you tried to removed the screws using a Phillips screwdriver. They are NOT Phillips screws, they are JIS (Japanese Industrial Standard) and Phillips screwdrivers will not fit the properly (see images below). If it was mine I would first soak that screw with Kroil for 3 days. Kroil will break the bond between the screw and the cylinder head. While it is soaking I would buy or make a JIS screwdriver tip. The tip should fit perfectly, otherwise the odds of the screw coming out are very slim. Ed
Last edit: 30 Jan 2019 19:07 by 650ed.
The following user(s) said Thank You: ERIK814
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Jan 2019 19:06
#797944
Pick up a hand impact driver, Use the best fitting bit, Tap on the bit to clean up the slots then drive it out. If you have to take out the air box then do it.
  • Nerdy
  • Nerdy's Avatar
  • Away
30 Jan 2019 19:24
#797945
SWest wrote: Pick up a hand impact driver, Use the best fitting bit, Tap on the bit to clean up the slots then drive it out. If you have to take out the air box then do it.
I picked up one of those *mumble* years ago, and love it. It's the kind of thing that if you need it, you need it.
The drawback in this situation is there may not be enough room to get the impact driver in there straight and centered and still get a good whack at it with a hammer. I have a twin (440) with the same issue, and right now I'm just planning to pull the engine because there's no room to operate.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • ERIK814
30 Jan 2019 19:40
#797950
I have been soaking with liquid wrench for about 5 days (4 applications over that period). Also used a vessel JIS #3. Photos attached. I definitely don’t have room for an impact driver without taking the air box out. How hard is that? Any other tips?
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Jan 2019 19:46
#797951
I never attack those screws without a hand impact. I reinstall them the same way. Taking the airbox out shouldn't be that difficult.
30 Jan 2019 19:50
#797952
ERIK814 wrote: I have been soaking with liquid wrench for about 5 days (4 applications over that period). Also used a vessel JIS #3. Photos attached. I definitely don’t have room for an impact driver without taking the air box out. How hard is that? Any other tips?
In that case you have been taking the correct approach. Maybe removing the airbox will help. On my KZ650 that was pretty easy once the carbs were removed On mine there were 2 screws (one on each side of the airbox) that were sort of hidden behind the side covers. Ed
  • z1kzonly
  • z1kzonly's Avatar
30 Jan 2019 19:56
#797953
Use some needle nose vise grips! Seeing you soaked it. Or use an impact!
That's an easy one!
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
30 Jan 2019 20:13 - 30 Jan 2019 20:14
#797954
Vampliers should work. They're also sold under the brand name Engineer. Anyone who appreciates fine quality tools will be pleased with either. We bought the three piece Vampliers set, but this individual plier should work for that screw.
www.amazon.com/Vampire-Professional-Tool...VT-001/dp/B006YJKAPQ
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 30 Jan 2019 20:14 by slmjim+Z1BEBE.
The following user(s) said Thank You: Nerdy
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Jan 2019 20:34 - 30 Jan 2019 20:34
#797955
Did you get the bottom screw out. If so you may be able to drive the flange to the right to loosen the screw.
Last edit: 30 Jan 2019 20:34 by SWest.
  • Nerdy
  • Nerdy's Avatar
  • Away
30 Jan 2019 20:35
#797956
slmjim+Z1BEBE wrote: Vampliers should work. They're also sold under the brand name Engineer. Anyone who appreciates fine quality tools will be pleased with either. We bought the three piece Vampliers set, but this individual plier should work for that screw.
Just ordered 'em. If they work I'll owe you at least a beverage or two. :)
The PO of my 440 said there was an intake leak so he used what looks like a full tube of silicon to try to seal around the boots. I'm replacing the carbs and the boots and removing the airbox, so the only real concern is getting the boot screws out without jacking up the head.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • davido
  • davido's Avatar
30 Jan 2019 23:23
#797957
Cut a slot with a Dremel and use a straight screwdriver ( helped by vice grips on the shaft ). Impact driver would be best though.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
