Stripped carb boot screw
  • KZB2 650
  • KZB2 650's Avatar
Re: Stripped carb boot screw
03 Feb 2019 04:52
#798099
I've taken a small sharp chisel to the head and using that turned the screw enough to loosen it up. You can also get a little more spray in that way and a pair of vice grips might be able to get it then. The cutting of a slot like you say might do it to but it would help to free it up a little first.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Nessism
  • Nessism's Avatar
  • Away
03 Feb 2019 05:12
#798102
Vice grips are a common tool that most hardware stores should have. I've successfully used them several times to break loose carb boot screws like shown. If you have to take a hammer and screwdriver and spin the boot out of the way to you can get a better angle at the screw. You should be changing those boots regardless do don't worry about possibly damaging them.
  • riturbo
  • riturbo's Avatar
03 Feb 2019 05:55
#798103
Yup Ive used vise grips too . Its my go to tool for screws like that if you can get them in there . Almost every carb i touch have to vise grip at least one screw . Try and get the real ones made by vise grip if you can . Most aftermarket ones are junk .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
03 Feb 2019 07:29
#798111
Don't forget heat.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • ERIK814
  • ERIK814's Avatar Topic Author
04 Feb 2019 17:26
#798208
Vise grips did it. Finally!!
Thanks for everyone's advice and help on this one!
Special F**K off to the rusty ass screw who gave me a headache all week.
1981 KZ 440 LTD Belt Drive (Late Model)
