77 KZ750B Twin Carb Rebuild
  • They Who Prevail
  • They Who Prevail's Avatar Topic Author
16 Jul 2018 16:11 - 16 Jul 2018 16:12
#787080
Hi everyone i am currently undergoing a starter clutch, head gasket, possible valve job, and carb rebuild i am waiting on the parts and gaskets ordered everything today 350$ for all the parts......anyway. The petcock that come on the bike i believe is aftermarket not stock. The bike is a 1977 KZ750B (twin) the petcock only has one fuel outlet on it and runs lean. There is a T in the fuel line between the carbs. when i am cruising 70+ the bike wants to putter out, i pull over and idle or just pull in the clutch for about 15 seconds and get back into it its fine for about 2 mins. City driving is fine but highway driving is fine as long as i don't exceed 55mph for too long. could this be a venting problem because the one fuel outlet off the petcock? I see they make a double outlet petcock for that bike i will invest in once i do the carb rebuild. thanks for the knowledge and help.
Last edit: 16 Jul 2018 16:12 by They Who Prevail.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 77 KZ750B Twin Carb Rebuild
16 Jul 2018 20:03
#787091
Did you check if the vent in the cap is clear? Try opening the gas cap and see if it clears. Could be the petcock is too small.
  • DoctoRot
  • DoctoRot's Avatar
17 Jul 2018 08:47 - 17 Jul 2018 08:50
#787111
My 750 twin was doing the same thing, turned out it was too small of float valve. I had 2.0 in there, I switched to 2.5 and it fixed it. The BS38 carbs use the same float valves as the 29 smooth bores so you should have no trouble finding some
Last edit: 17 Jul 2018 08:50 by DoctoRot.
