Setting float levels Wet Method
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
05 Mar 2018 14:25
#779789
Hi Folks,
I'm about to embark on a float level adjustment project on a couple of different configurations of carbs. In the past I've just taken a chance that I won't start a fire on my work bench. I'm thinking that I'll rig a temporary fuel tank up high with some sort of cut off valve. I'll have the carbs mounted in various ways over an aluminum catch tray. In case things really get out of hand I'll have a fire extinguisher ready but I'd really prefer to not contaminate everything with extinguisher powder. What would you think of a custom fabricated metal lid or cover that I could just put over the whole thing in case of a fire?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • TexasKZ
  • TexasKZ's Avatar
Re: Setting float levels Wet Method
05 Mar 2018 15:49 - 05 Mar 2018 16:00
#779791
That would work, but isn't there a less flammable option to gasoline?
Mineral spirits are les s volitle and should still work.
I think the safest option would be a calibration fluid like Viscor. I think it sells for around $60 per gallon, but it is reusable and way cheaper and safer than a blast cabinet :ohmy:
www.rockvalleyoil.com/cf.html
Last edit: 05 Mar 2018 16:00 by TexasKZ.
  • zukdave
  • zukdave's Avatar
05 Mar 2018 17:16
#779795
Thing's float because they weigh less than the liquid it's it's floating in you change the liquid the float weigh need to be heavier
or lighter depending on the weigh of the fluid to keep the level the same.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Nessism
  • Nessism's Avatar
  • Away
05 Mar 2018 18:15
#779799
I use gasoline, Just keep all electrical equipment away of any drip and splash. A catch pan sounds like a good idea so please share a photo of your setup when you get that far.
  • TexasKZ
  • TexasKZ's Avatar
05 Mar 2018 18:50
#779802
True, and that is the point of calibration fluid.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Mar 2018 20:54 - 05 Mar 2018 20:57
#779805
As long as you have good ventilation you shouldn't have any problems.
Last edit: 05 Mar 2018 20:57 by SWest.
  • scubaanders
  • scubaanders's Avatar
05 Mar 2018 21:32
#779809
I usually have a thin hose that runs down to a container under the work bench, that I attach to the float bowls and drain them one after the other before I open up the bowls again.
All fuel ends up in the container and there is usually no spill.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
06 Mar 2018 09:16
#779831
KZQ wrote: Hi Folks,
Bill
Can set correct fuel level in just one carb using the clear tube test with gasoline.
Then use another fluid of choice -- such as odorless mineral spirits, common household rubbing alcohol (my fave), or even tap water -- in the same known "correct" carb to determine the level inside the clear tube using the chosen alternate fluid (which has a different specific gravity), which level will be either somewhat higher or lower depending on whether it's specific gravity is lower or higher than the specific gravity of gasoline.
And make note of the level inside the clear tube produced by the alternative fluid, which then is the "within spec" level for the alternate fluid which will produce the correct "within spec" level when using gasoline.
Having one known correctly adjusted carb, the remaining clear tube testing and adjusting can be done inside sitting comfortably at the kitchen table without any danger of fire or gasoline fume inhalation or the obnoxious stinkin' odor of gasoline.
Good Fortune! :)
The following user(s) said Thank You: dkoz
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
06 Mar 2018 10:59 - 06 Mar 2018 11:02
#779835
Bill[/quote]
Good Fortune! :)[/quote]
^That. Exactly.^
We tried all manner of (relatively) benign liquids as alternatives to gasoline where we were searching for ways to do carbs in our basement workshop during winter months. A standing pilot light in the water heater dissuades us from using gasoline.
We tried:
distilled water
kerosene
antifreeze
rubbing alcohol
turpentine
None matched gasoline in a wet test.
Never heard of "calibration fluid".Sounds interesting. Link?
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 06 Mar 2018 11:02 by slmjim+Z1BEBE.
  • kevski
  • kevski's Avatar
06 Mar 2018 12:15 - 06 Mar 2018 12:15
#779836
Jeez, what are we all fairies here! here's what to do, no naked flames, no electrical appliances running, no smoking, keep well ventilated, do the job, ride the bike.:huh:
Last edit: 06 Mar 2018 12:15 by kevski.
  • KZQ
  • Administrator
  • Administrator
08 Mar 2018 11:21
#779929
Thanks folks!
I'm going to try just turning off as many electrical circuits as I can. I've got a good exhaust system which I'll crank up. I'm thinking that I can fold and spot weld a box/cover to just set over the whole thing if the worst happens. I'll post some picks as I get closer.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • KZQ
  • Administrator
  • Administrator
08 Mar 2018 11:37 - 08 Mar 2018 11:39
#779931
I think I've found a good multi use product that will serve to smother any fire I might start.
How about a welding blanket?
www.amazon.com/dp/B002WPJ04I/ref=psdc_10704399011_t2_B00ECG8JTM
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 08 Mar 2018 11:39 by KZQ.
