- Thank you received: 15
idle
- tthunderdan
19 May 2017 21:57 #762259
by tthunderdan
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
idle was created by tthunderdan
On my newly aqquired 83 kz1100 the motor does not snap back to idle like I feel it should. I notice it mostly coming to a stop. Another thing I notice is the choke knob want to pop back out to almost first position, which I push back in and it idles down ok then. Other than that the bike (although cold blooded) starts and runs very well. Any ideas to the cause of this?
Dan
Dan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
- Thank you received: 2838
20 May 2017 04:18 #762261
by Nessism
Replied by Nessism on topic idle
Bad cables?
If the idle is hanging and not settling down quickly that could be an air leak. Replace carb boots on the head and possibly the boots at the back of the carbs too. Some people spray stuff on the carbs and listen for engine speed changes as a way of finding vacuum leaks but in my experience that method is not 100% reliable.
- tthunderdan
20 May 2017 07:18 #762278
by tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
Replied by tthunderdan on topic idle
can you imagine what would make that choke knob work back out to about the first sto?
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
- Thank you received: 2755
20 May 2017 07:28 #762283
by SWest
Replied by SWest on topic idle
Can't help with what we can't see.
- tthunderdan
20 May 2017 07:37 #762285
by tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
ok
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
20 May 2017 08:22 #762290
by SWest
No slight intended, pics help.
- tthunderdan
20 May 2017 11:21 - 20 May 2017 11:22 #762301
by tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
I understand. No problemo, it is awkward to get a vid of it popping out by myself and reving it. I have included a pic of the choke set up.on this. I lnow the knob is broken off. Please look at this and see if it is correct. Should the little spring be on the outside of that bracket and helping to hold it in? My manual isnt real clear in its pic of choke knob. setup. And what is the thumbwheel in the center of the 4 carbs coming out the back of carbs? Kinda hard to see.
Dan
Dan
Attachment not found
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
Last edit: 20 May 2017 11:22 by tthunderdan. Reason: pics
20 May 2017 12:45 - 20 May 2017 12:46 #762306
by SWest
That's the idle adjustment screw. Looks liike you're missing the snap ring on the choke plunger.
Last edit: 20 May 2017 12:46 by SWest.
20 May 2017 12:57 #762308
by SWest
Something like this.
jetsRus.com
jetsrus.com/choke_repair_kit/choke_repai...election.html#street
jetsRus.com
- tthunderdan
20 May 2017 13:16 #762310
by tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
and the snap ring on my setup would be directly under my missing black knob?
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
20 May 2017 13:39 #762314
by SWest
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a pic. No snap ring I can see.
- tthunderdan
20 May 2017 14:19 #762319
by tthunderdan
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
and the u shaped little steel chanel piece looks strait on the ebay one compared to my bent u shaped little steel channel piece. hmmmmm
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
