VM26 Specs Needed
VM26 Specs Needed
12 Nov 2016 20:24 - 12 Nov 2016 21:15
I'm almost done rebuilding a set of VM26's and could use some help with the following:
- float height
- fuel level
- stock jetting : main and pilot. Currently 107.5 and 17.5. I realize that there may be different jetting for different years but wondering about a baseline.
- pilot fuel screw setting.
I don't know which model KZ these came from. They are just the standard VM26's. Nothing fancy.
Thanks in advance.
- float height
- fuel level
Thanks in advance.
Last edit: 12 Nov 2016 21:15 by Nessism.
Re: VM26 Specs Needed
12 Nov 2016 21:06
Looks like they are 77 KZ 1000 carbs. The KZ 900 had 115 mains, 17.5 pilots. The 1000 carbs had the same pilots. Needles on the 900 was 5DL31-3rd and the 1000 was 5CN8-3rd. Float level 22mm 900 vs 25mm 1000's. There's more for the later carbs as well. Seems they got leaner still.
12 Nov 2016 21:18
What about the pilot fuel screw setting Steve? The screw has a plastic cap which allows about 1/8 of a turn for tuning.
12 Nov 2016 21:47
1 3/8 +- 1/4 and 1 1/4 +- 1/4. I'll try to take a pic of the page in the morning. With the cap they sound later than these.
13 Nov 2016 06:57
This camera doesn't take very sharp pics. Let me know if you can read it. I used paint but when you flip it, it gets worse.
13 Nov 2016 07:45Nessism wrote: I'm almost done rebuilding a set of VM26's and could use some help with the following:
- float height
- fuel level
Thanks in advance.
From the FSM covering Z1 through KZ900:
- KZQ
- Administrator
13 Nov 2016 07:57The FSM manual doesn't address float height but it specifies that the fuel level should be 1/8" below the edge of the carburetor body.Nessism wrote: I'm almost done rebuilding a set of VM26's and could use some help with the following:
- float height
- fuel level...
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
13 Nov 2016 08:10 - 13 Nov 2016 08:11Patton wrote:Nessism wrote: I'm almost done rebuilding a set of VM26's and could use some help with the following:
- float height
- fuel level
Thanks in advance.
Not knowing what bike these carbs came from it is helpful to have the spcs from a full range of years. Ed what needle do you have. That might give a clue.
Last edit: 13 Nov 2016 08:11 by SWest.
13 Nov 2016 10:11 - 13 Nov 2016 11:50
Thanks for the info guys.
I'll pull one of the needles and look for numbers, and provide some photos in a little while. I can tell you that these carbs don't have an air screw, just the fuel screw on the bottom.
P1030324
by
nessism
, on Flickr
Last edit: 13 Nov 2016 11:50 by Nessism.
13 Nov 2016 11:51
13 Nov 2016 11:52
14 Nov 2016 04:50 - 14 Nov 2016 05:00
This diagram may be helpful to viewers less acquainted with the different pilot circuits in Mikuni 26mm manual slide carbs:
Stock 1976 KZ900 has 26mm Mikuni with side-located pilot air screw.
Stock 1977 KZ1000-A1 and 1978 KZ1000-A2 have 26mm Mikuni with bottom-located pilot mixture screw.
Turning out pilot air screw adds air which leans the mixture.
Turning in pilot air screw reduces air which enriches the mixture.
Turning out pilot mixture screw adds mixture which enrichens the intake.
Turning in pilot mixture screw reduces mixture which leans the intake.
Per FSM covering 1977 KZ1000~1979 KZ1000:
1977 KZ1000-A1
Mikuni VM26SS (Pilot Mixture Screw)
Main Jet 107.5R
Needle Jet 0-6
Jet Needle 5CN8-3
Pilot Jet 17.5
Pilot screw 1¼ ± 1/8 turn out
Throttle Valve Cutaway 1.5
Design Fuel Level 32 ± 1mm
Service Fuel Level 3.0 ± 1mm
1978 KZ1000-A2
Main Jet 105R
Needle Jet 0-5/2
Jet Needle 5DL31-3
Pilot Jet 15
Pilot screw 1.0 ± 1/8 turn out
A3 and D1-2 stock have VM28SS with side-located pilot air screw.
1977 KZ1000-A1
Main Jet 107.5R
Needle Jet 0-6
Jet Needle 5CN8-3
Pilot Jet 17.5
1978 KZ1000-A2
Main Jet 105R
Needle Jet 0-5/2
Jet Needle 5DL31-3
Pilot Jet 15
Last edit: 14 Nov 2016 05:00 by Patton.
