1976 KZ900 A4 ........Where do the rubber O-Rings?
- Katums
Re: 1976 KZ900 A4 ........Where do the rubber O-Rings?
05 Nov 2016 05:37
Patton,
BTW, your videos are not only highly informative, but LOL funny at the same time. You got talent!
Katums
Katums
1976 KZ900 A4
2003 Porsche Boxster S
05 Nov 2016 15:09
Took apart a set of VM26's today and found O-rings on the Needle Jets (the piece the main jet screws into).
05 Nov 2016 15:30
I don't remember seeing any. I'll have to pull the emulsion tubes on my 28's to see if there are any there as well. They are identical except the nozzles are smaller. Hmmmm.
- missionkz
05 Nov 2016 16:35 - 05 Nov 2016 16:36if you two mean the emulsifier emulsion tubes, both my 26mm sets have o rings there.swest wrote: I don't remember seeing any. I'll have to pull the emulsion tubes on my 28's to see if there are any there as well. They are identical except the nozzles are smaller. Hmmmm.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 05 Nov 2016 16:36 by missionkz.
05 Nov 2016 17:08
I pulled a set apart years ago to see if the parts were interchangeable. The slides were the same and the floats, I think the needle and seats were too. Everything else were different. Why I did it I don't know. Bored I guess. That was STUPID. :blink:
- Katums
05 Nov 2016 18:04
Hmmmmm.....not on mine so far. I have all the brass out except the needle. So far, no rubber O-rings.
However, after hearing from Patton, I think it was, I inspected the gas transfer tees and in fact, as he suggested, found them to be cracked and dried out and in total need of renewal SO that was an insightful observation on his part.
Now I need to break them down and separate them from their mounts. I'll clean them up well and dip them.
1976 KZ900 A4
- Katums
05 Nov 2016 18:11
You are correct, the fuel tees are cracked and dry and need replacement. Thanks for the tip, I now will need to separate them and clean the internals and externals.
In the end, it will be worthwhile to go through them and clean up the linkages and hardware at the same time.
Thanks, All
Katums/Ed
Thanks, All
Katums/Ed
1976 KZ900 A4
