- Thank you received: 8
Switching wires
- stokes
1980 KZ1000B Ltd
- Thank you received: 2829
- Thank you received: 2755
- stokes
1980 KZ1000B Ltd
- Thank you received: 2098
A too high fuel level in an otherwise perfect carb results in an over-rich mixture which might combust okay for a short time with a brand new plug until fouling out the new plug.
- Tyrell Corp
- Thank you received: 261
- stokes
1980 KZ1000B Ltd
stokes wrote: . . . getting no gas or not enough to #3 since the plug looked normal after about 25 miles of riding with this problem.I assume it is firing some,since the pipe gets hot,but not as hot as the others.
Yes, the normal looking plug indicates something other than a too rich mixture.
Possibly insufficient amount of mixture being received from carb #3 (such as imperfect pilot circuit);
And/or insufficient spark for whatever reason on plug #3.
If applicable, old hard cracked voltage-leaking worn-out plug wires should be replaced.
I prefer the longer-lasting solid core plug wires (as used in stock) over the resistance type plug wires. But it's just a personal preference, as the resistor style spark plug wires are expected to perform equally well provided they are accompanied with non-resistor caps and aren't accompanied with "R" spark plugs.
- stokes
1980 KZ1000B Ltd
- stokes
1980 KZ1000B Ltd
