Pilot Plug - Aluminum or Rubber or Other?
- McKinneyRacing
26 May 2016 11:52
Which is your personal preference? I recently did a carb rebuilt and the aluminum/o-ring plug went in fine, I just prefer a good snug feeling which it did not give me. Which holds up to modern fuel and stays put is my overall question.
- DoctoRot
Re: Pilot Plug - Aluminum or Rubber or Other?
31 May 2016 10:44
i replaced the o-ring with a slightly larger one in my kz400 carbs and it worked great.
- JR
31 May 2016 11:45McKinneyRacing wrote: Which is your personal preference? I recently did a carb rebuilt and the aluminum/o-ring plug went in fine, I just prefer a good snug feeling which it did not give me. Which holds up to modern fuel and stays put is my overall question.
What bike and what brand carb ? and will the same plug fit a range of carbs?
My Keihin CV 34 carbs take a plastic or is it neoprene plug with o ring over the pilot jet and if i ever drop and lose one I have a problem . I have seen metal plugs with o rings and think these were for a Mikuni BS34 . Wonder if they would fit Keihin carb? or any size CV32 CV34 or CV36.
Personally i dont care what they are made off but an availabe alternative would be nice.
I tried straight rubber plugs made for a GS or goldwing a few years back but they fell out after a week. Seems the Mikuni carbs have a bowl design to hold them in place. Something the Keihin float bowl doe not have.
- Skullcrusher
01 Jun 2016 14:13
I understand that some bikes for whatever reason block off the pilot circuit from factory but can anyone tell me why? And how do they get around The whole not having a pilot circuit? Shorter needle? Skinnier tapered needle?
Bikes: 82 kz750 CSR, 03 Suzuki gsf1200s (stage 2), 73 CB 750 bored to 849, big cam, ports head, big valves, lots of other goodies....
01 Jun 2016 14:45
It depends on the ones over the pilot screws or the ones over the pilots.
The screws are covered so they can't be tampered with. The ones over the pilots are so they have to get fuel through the main circuit.
The first isn't needed, the second is.
- loudhvx
01 Jun 2016 22:04
We are talking inside the bowl...
The carbs that have a plug over one of the jets, have an alternate passage for fuel to get to the covered jet. The pilot circuit is not removed, it just gets fed differently. Not sure why some need this and some don't. It seems more like a modification to an earlier version of the carb, like a change to meet some emissions mandate, etc.
Two different model carbs can sometimes look almost identical, but one will plug the pilot, or intermediate jet. The blocked jet will sometimes get fed through the main jet.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Skullcrusher
02 Jun 2016 06:07
Ah, I see. I've never personally had a bike with this particular feature, seems like a cheap work around alternative to sourcing a carb that better suits the motor.
02 Jun 2016 06:08
I know that. Just explaining to crusher the two types. The one connected to the main circuit is to limit how much the pilot circuit can get.
Emissions. :pinch:
Emissions. :pinch:
- McKinneyRacing
02 Jun 2016 08:51
Yes I'm referring to the BS34 series carbs. I've been working on several of these cop bikes, and it seems that the previous owner simply left the plugs out of the carbs or they came this way from the factory. I saw the rubber plugs for sale at Z1Ent. but wasn't sure how well they held up to modern fuel and ethanol exposure.
Looking down the pilot jet hole, they are fed via a small passage from the main jet. I know two of these bikes seem to run fine when we rode them back and they didn't have any plugs either.
02 Jun 2016 10:18
If I'm not mistaken the passages are after the main jets. If that's the case, you have a wide open with no jet metering the mains.
- drmiller100
02 Jun 2016 16:56
here is the theory.
most carbs have a main jet and an idle jet which suck fuel from the float bowl. if you change the pilot, it WILL affect the main jet ever so slightly, but the difference is really insignificant.
Some carbs feed the pilot circuit from the main jet circuit. Theory here is the huge main jet flows plenty for the pilot. If you change the pilot, it won't change main jet performance, as it all still flows through the main.
So, those which feed the pilot from the main jet have the passage way mentioned. this passage way CAN be plugged.
Also, the style of pilot jet can be different depending on which way it feeds.
some guys convert some carbs. they remove the plugs, the plug the passage way between the main and the pilot. seems silly to me. seems much easier to just leave the plugs in.
