Confirming what carbs, '80 kz650
  • MadShad
  • MadShad's Avatar Topic Author
25 May 2016 06:44
#728408
1980 kz650 f1,
So I've got the carbs off the bike and the bowles off the carbs.
I have a single fuel inlet, single pump on the #2 carb bowl WITHOUT the second pump diaphragm and cap.
From what I've read that means that I have the vm28's, sound right?
I need a bowl gasket and one of the impossibly tiny wire clips for the accelerator pump check valve.
Looking for gaskets and rebuild kits I see several for '77-79 kz650 but nothing for the '80 f1.
Anybody got a line on those parts?
I'm also still looking for a service manual to download for the 1980 kz650.
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Confirming what carbs, '80 kz650
25 May 2016 06:49
#728410
Have you tried jetsrus.com/ ?
  • MadShad
25 May 2016 07:10 - 25 May 2016 07:10
#728411
Looks like I'll need to wait until I get home and in front of a computer, jetsrus.com and a smartphone don't mix well, lol.
Looks like they do list 2 part numbers for the bowl gasket.
Last edit: 25 May 2016 07:10 by MadShad.
25 May 2016 07:11
#728413
Post a picture of your carbs that shows the whole carb from the back side. If you do that I can tell you if they are stock KZ650 Mikuni VM24SS or Mikuni VM22SS carbs. If they are neither of those someone else may be able to tell you exactly which carbs you have. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • MadShad
25 May 2016 07:27
#728419
650ed wrote: Post a picture of your carbs that shows the whole carb from the back side. If you do that I can tell you if they are stock KZ650 Mikuni VM24SS or Mikuni VM22SS carbs. If they are neither of those someone else may be able to tell you exactly which carbs you have. Ed
I'll take some when I get home, I took pictures of the bowls but not the bodies.
The clips on this page looks like what I'm after!
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 May 2016 07:33
#728420
If that's all you need, why not make your own out of a spring from a ball point pen?
  • MadShad
25 May 2016 07:39
#728421
Already have a pen apart on the bench. :)
Also need a bowl gasket and I'm waiting for my megaphone baffle so I can figure out jets and needle height.
The needle is marked 5cl30 and is adjusted with shims I'm guessing?
  • martin_csr
  • martin_csr's Avatar
25 May 2016 08:17 - 25 May 2016 08:18
#728430
MadShad wrote: 1980 kz650 f1,
Kawasaki disabled the vacuum sensor on the VM24s after 1978 or 79.
My 81 650-csr w VM24s has the accelerator pump w triangular flange but it doesn't have the vacuum sensor stuff.
Last edit: 25 May 2016 08:18 by martin_csr.
  • MadShad
25 May 2016 09:39
#728463
Vm24's? Found an old post of yours Ed.
25 May 2016 10:15
#728469
Yes, those are stock KZ650 Mikuni VM24SS carbs. Ed
The following user(s) said Thank You: MadShad
  • rrsmsw9999
  • rrsmsw9999's Avatar
25 May 2016 12:48
#728498
A pen spring may work. I bought a couple of stainless springs at the hardware store (3$) of the correct diameter and snipped of a link and bent them into the shape of the clip. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
