Pilot jet sizing?
Re: Pilot jet sizing?
03 Jun 2016 07:00
If the needles are adjustable you just move the clip down to richen it through the RPM range or up to lean it out.
- loudhvx
03 Jun 2016 07:05
I would shim the needles. Check my tk22 site on how to do it properly with shimming the slide holder with wire.
Usually you don't need to go a full clip position if you compensate with mains and pilots. So you can still use stock needles.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- ajbonert
03 Jun 2016 07:11
Thank you! I will try after work and keep you posted on what happens
82 kz550 bobber
