Pilot jet sizing?
  • ajbonert
  • ajbonert's Avatar Topic Author
Re: Pilot jet sizing?
26 May 2016 13:04
#728691
Took side 37 pilots out of a buddy of mine's bike and now it runs damn good but it idled for awhile good then it shut off and now won't start not with choke on or off
82 kz550 bobber
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • ajbonert
26 May 2016 13:22
#728695
There is spark I believe it is still fuel related had all mixture screws start at 1 3/8 turn has to turn to approx 2 and they got better just don't know what else it could be weather syncing the carbs will fix or what
82 kz550 bobber
  • ajbonert
31 May 2016 08:23
#729338
Alright took the bike out this weekend for a few miles and runs good at low Rpms once I get about 1/4 throttle it starts to pop and loose power idles good drives good just not at higher Rpms could carb syncing be my problem now or do you think the main is to lean yet?
82 kz550 bobber
  • loudhvx
  • loudhvx's Avatar
31 May 2016 09:01
#729339
Carb sync affects mainly idle. Past 1/16 throttle, it should not matter.
Assuming the motor and ignition are working properly,
Does it run worse if you open the throttle quickly or slowly? If it runs worse opening quickly, then it's probably rich, If it's worse when opening slowly, then it's probably lean. This would be the range where the needle has the most affect. But a main that's significantly off can contribute as well.
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 May 2016 09:28
#729345
Does it sound hollow when you open it up?
  • ajbonert
03 Jun 2016 06:14
#729783
What seems to happen is if I roll into it quick or slow doesn't change it at full wide open throttle it runs as good as I believe it should but if I roll off the throttle about 1/16 to 1/8 of a turn from wot it starts cutting and popping and as for if it sounds hollow it is hard to answer that due to the pod filters I can't really tell if it sounds hollow or not with them because they make the bike sound night and day different. Sorry for the late response been working on a few different projects
82 kz550 bobber
  • Skullcrusher
  • Skullcrusher's Avatar
03 Jun 2016 06:35
#729795
I'd start by lowering the needle clip one notch, see if it gets better or worse.
Which pods are you using?
Bikes: 82 kz750 CSR, 03 Suzuki gsf1200s (stage 2), 73 CB 750 bored to 849, big cam, ports head, big valves, lots of other goodies....
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jun 2016 06:41
#729798
The needles are the last thing you touch. Fine tuning. Sounds lean to me. I'd go up one full step on the mains. 112 to 115.
  • ajbonert
03 Jun 2016 06:50
#729803
The needles are unadjustable and I have 104s you think I should do like 107s or go all the way to 112s?
82 kz550 bobber
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jun 2016 06:54
#729805
I was looking at this chart not knowing what carb style you have. They go in 1/2 steps. I'd go one full step with the needle in the center position. That way you can drop the needle or raise it to fine adjust.
jetsrus.com/a_jets_by_carburetor_type/je...main_Large_round.htm
  • ajbonert
03 Jun 2016 06:58
#729808
Can I just buy like a spacer or washer rather then buy new?
82 kz550 bobber
