750 twin air box compatibility
- Skullcrusher
14 May 2016 08:35
Hey all, new member here. I used the search function but couldn't turn up an answer so I'm starting a thread. If the answer was buried in the archives somewhere I apologize.
Just traded a pistol for a non running 82 750 CSR and after doing some very basic stuff got it fired up. The air box is gone and it has those cheap emgo pods and still has stock jetting. I can't find an 82 air box online but there's a guy on Facebook that has a 76-79 box. My question is: will it fit?
Bikes: 82 kz750 CSR, 03 Suzuki gsf1200s (stage 2), 73 CB 750 bored to 849, big cam, ports head, big valves, lots of other goodies....
- AtLarge
Re: 750 twin air box compatibility
14 May 2016 11:21
I know the carbs are different so the mating tube will not be the same diameter. A parts explosion will probably show if the mounting tabs are the same. Air cleaners are different size too. Partszilla has the drawings.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
The following user(s) said Thank You: Skullcrusher
- Skullcrusher
14 May 2016 11:49
Any advice on petcock rebuild kits? Can't seem to find one specifically for the kz750 CSR.
- DoctoRot
14 May 2016 12:36
The frame is different on the CSR twins so the airbox is different. according to partzilla the petcock is the same as the later kz400, kz440 and kz550 so you can use that to search as well. you might try one of these.
www.amazon.com/Valve-Petcock-KAWASAKI-KZ...iveASIN%3DB00B4XDO8M
- AtLarge
14 May 2016 14:00Ya dont. Plug the vacuum ports and go with an after market. The OE petcocks are a PITA.Skullcrusher wrote: Any advice on petcock rebuild kits? Can't seem to find one specifically for the kz750 CSR.
1973 Honda CL70-K3
1994 BMW K1100RS
1994 BMW K1100RS
14 May 2016 15:45 - 14 May 2016 15:46
Assuming your bike is a 1982 KZ750-M1 (CSR) twin according to
www.powersportswarehouse.com/p/Kawasaki#...0-M1-1982/080102C-11
the following bikes share you model's airbox (part #11010-1158) :
KZ750-K1 LTD Belt (1983)
KZ750-K2 KZ750-K2 (Canada Only) (1984)
KZ750-M1 CSR Twin (1982)
Last edit: 14 May 2016 15:46 by 650ed.
- Skullcrusher
14 May 2016 18:29
Awesome, found a complete box on eBay. Boots are rotted but otherwise good.
- Skullcrusher
14 May 2016 18:32
Ordered that petcock, damn thing takes a month to ship! Oh well, it's only got a slow drip.
- DoctoRot
15 May 2016 03:11
Yeah its a cheapo from China. I had one on my kz400 and it worked OK.
- AtLarge
15 May 2016 05:14
All the aftermarket petcocks are knockoff's of knockoff's. Ebay is full of them and I doubt even Kawi/Yammy/Zook branded with labels are even true Jap quality. Few last very long so plan to keep a new one on hand just like spare fuel line and filters.
One other thought on your airbox. Make sure you get the rings on the housing. The rubber tubes will most likely be unusable and irreplaceable but there is a work around for that. You may get lucky and still be able to use the ones that come with it but chances are they won't last for long.
1973 Honda CL70-K3
1994 BMW K1100RS
1994 BMW K1100RS
- Skullcrusher
15 May 2016 10:41
What is the work around? Radiator hoses?
- DoctoRot
