750 twin air box compatibility
- AtLarge
Re: 750 twin air box compatibility
16 May 2016 04:49Skullcrusher wrote: What is the work around? Radiator hoses?
That's an option but, with limited success. I have seen shrink tubing used over the old tubes. Still makes them stiff and difficult to work with. I used rack and pinion boots. Perfect seal at both ends. Easy to get on and off the carbs. Over 5 years on mine now and no signs of deterioration.
Linkie
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
- Skullcrusher
16 May 2016 08:02
Briliant idea, do you have a specific part number or what? Any details on this would be very helpful.
Bikes: 82 kz750 CSR, 03 Suzuki gsf1200s (stage 2), 73 CB 750 bored to 849, big cam, ports head, big valves, lots of other goodies....
- AtLarge
17 May 2016 05:01
The part number I used from Moog is in Biquetoasts blog at the bottom. They are a little pricey at $25 a pop but well worth it to me. There are probably other brands available that you can save a buck or two on. Just have the counter man do a cross reference in their system or look on their shelf for test fit. Get the right orientation before cutting. Be sure to sandwich the bellow between the box and the ring as shown. I use the OE carb springs around the throat of the carb but it's really more for cosmetics than necessity. You should be GTG.
1973 Honda CL70-K3
1994 BMW K1100RS
1994 BMW K1100RS
