Fuel mileage
  • Willy1803
  • Willy1803's Avatar Topic Author
Fuel mileage
13 May 2016 11:15
#726184
Is it bad that I'm getting about 25 mpg
  • jakeshort42
  • jakeshort42's Avatar
Re: Fuel mileage
13 May 2016 11:16
#726185
What are you riding? I get about 40 riding my 80 KZ440LTD like an idiot. 55 or so if I behave.
  • Willy1803
Re: Fuel mileage
13 May 2016 11:18
#726187
1977 kz650
Re: Fuel mileage
13 May 2016 11:28 - 13 May 2016 11:29
#726191
You need to have someone perform a full tune-up. You should get a t least 30 mpg even if you ride REALLY hard. Also, what rpm are you shifting at? Ed
Last edit: 13 May 2016 11:29 by 650ed.
  • Willy1803
Re: Fuel mileage
13 May 2016 11:42
#726196
7000 rpm an I have no plugs wire an carbs rebuilt
Re: Fuel mileage
13 May 2016 11:50
#726198
You're burning a lot of extra fuel if you routinely shift at 7000 rpm. Unless you are racing someone (it happens) try shifting earlier - say around 3500 rpm and see if your mpg improve. Ed
  • pete greek1
  • pete greek1's Avatar
Re: Fuel mileage
13 May 2016 11:54
#726202
Willy1803 wrote: 7000 rpm an I have no plugs wire an carbs rebuilt
What do you mean you have NO plugs wire??
& that's bad gas mileage, & I see you have another thread about looks
Do like 650ed suggested & tune up bike & get it running right, before worrying about looks, looks wont get you anywhere if your bike don't run properly
Pete
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Fuel mileage
13 May 2016 12:12
#726207
I was getting 42 MPG dependable with my 28's. Now I get 30-35 with my 33's. Been trying to lean it out but I guess I'm stuck with what I got. :unsure: Don't help having a heavy hand ether. :woohoo:
  • Willy1803
Re: Fuel mileage
13 May 2016 12:22
#726211
Now plugs an wires sorry
  • GPzMOD750
  • GPzMOD750's Avatar
Re: Fuel mileage
13 May 2016 17:26
#726245
You are revving way too high for regular riding. Don't ride like you're at the drag strip at every light and you wont be making Al Gore cry. You shouldn't be shifting above 5k in traffic and that's only if the devil's on your ass with a pitch fork. Shifting between 3-4K will get you there quick enough. Your rear tire will last much longer as well.
I'm getting about 45 mpg and I ride like an idiot IMO. I'm sure I could milk it to the mid 50s if I behaved myself. I cruise @ 85/6k on the highway to work. I also went larger on my drive sprocket to help that.
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
Re: Fuel mileage
13 May 2016 17:57
#726263
GPzMOD750 wrote: You are revving way too high for regular riding. Don't ride like you're at the drag strip at every light and you wont be making Al Gore cry. You shouldn't be shifting above 5k in traffic and that's only if the devil's on your ass with a pitch fork. Shifting between 3-4K will get you there quick enough. Your rear tire will last much longer as well.
Good advice. Shifting at 5K will beat most cars in traffic, and my 550 will still gets 50 mpg doing that.
1982 Kawasaki KZ550 LTD
  • bluej58
  • bluej58's Avatar
Re: Fuel mileage
14 May 2016 05:32
#726336
What do your plugs look like?
78 KZ1000 A2A
