Rebuilt Petcock, super tight
- akolleth
05 Apr 2016 07:41 - 05 Apr 2016 07:43
1982 KZ750 H. Had my carbs overflow into the case and ruin the oil. One of the fixes I am doing is rebuilding the vacuum petcock with a K&L rebuild kit. Took the petcock apart and the diaphragm was ripped, hence why the overflow. The rebuild is easy enough to do but I ran into an issue. The o ring that fits around the handle assembly is a really tight fit in the petcock body. As in its so tight its difficult to get the handle into the body and it makes it almost impossible to rotate the lever when the handle is in.
Any tricks to massage it into a better fit? I have heard about maybe using petroleum jelly? Old o ring ripped when it was removed so no go in re-using that one.
The light that burns twice as bright, burns half as long. And you have burned so very, very brightly Roy.
Last edit: 05 Apr 2016 07:43 by akolleth.
Re: Rebuilt Petcock, super tight
05 Apr 2016 07:59
A light coat of grease should do it.
- car5car
- Banned
05 Apr 2016 09:00
Lever (round surface) has to be sanded step by step with last sandpaper grade 1000 or 2000.
Round rubber gasket has a lip, it goes toward tank.
96 Yamaha Royal Star
82 Yamaha Virago 920
- RonKZ650
05 Apr 2016 13:31
Probably too large of diameter oring in the kit. Most likely the part is still available from Kawasaki.
- akolleth
06 Apr 2016 07:18 - 06 Apr 2016 07:19
Called up the local metric dealer and got the O ring ordered from the manufacturer-- Its going to break me at a whopping $3
just in case anyone comes across this same issue the part number from Kawasaki is 92055-1027 and it is still available
Last edit: 06 Apr 2016 07:19 by akolleth.
- baldy110
06 Apr 2016 08:36car5car wrote: Lever (round surface) has to be sanded step by step with last sandpaper grade 1000 or 2000.
Huh?
- ThatGPzGuy
06 Apr 2016 11:00car5car wrote: Lever (round surface) has to be sanded step by step with last sandpaper grade 1000 or 2000.
Yep, sand the surface smooth on a flat surface. A piece of glass works. I also flatten all the sealing surfaces. Use fuel resistant grease on the face and the o-ring.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- baldy110
- ThatGPzGuy
06 Apr 2016 11:49
Pretty good petcock rebuild write-up.
www.xs650.com/forum/showthread.php?t=206...ight=petcock+rebuild
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- pete greek1
06 Apr 2016 12:22Nice tutorial !!ThatGPzGuy wrote: Pretty good petcock rebuild write-up.
Pete
- baldy110
06 Apr 2016 19:01
Ok, after reading that tutorial it makes much more sense.
- davido
07 Apr 2016 08:48
I had the same problem when I rebuilt mine about 2 years ago. As the bikes still not on the road yet,I havent got round to sorting it out. Will get to it soon though so let us know how yours works out and if the O-ring sorts it (and/or the sanding). I did grease mine but it didnt make much difference.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
