Rebuilt Petcock, super tight
  • tri650
  • tri650's Avatar
Re: Rebuilt Petcock, super tight
07 Apr 2016 17:53
#719796
I am having the same issue. The o-ring is too big. It will barely turn. Now it won't turn off when on Res or On. I have taken it apart 3 times. It works as it should while sitting on the bench. When I hook everything up and run it it starts flowing while on Res or On. It has a rebuilt kit on it. Any suggestions?
  • tri650
  • tri650's Avatar
07 Apr 2016 18:57
#719808
I think I figured it out. The diaphragm was not seated correctly - it was kind of off center so it looked like the seal was not complete. I followed the instructions on rebuilding to make sure the passage was properly aligned and that seemed to seat it better. Anyway, I re-assembled and checked it out. No leaking when on Res or On. I went back to the old O-ring as the new one is too big. No leaks and it turns easier so I will stick with it.
  • tri650
  • tri650's Avatar
07 Apr 2016 18:59
#719811
One more thing - If I understand this correctly the vacuum pulls the diaphragm away from the seal part so it flows fuel when on Res and On?
  • Little B
  • Little B's Avatar
08 Apr 2016 21:38
#720002
tri650 wrote: One more thing - If I understand this correctly the vacuum pulls the diaphragm away from the seal part so it flows fuel when on Res and On?
yep
1981 KZ750-H2 LTD
  • akolleth
  • akolleth's Avatar Topic Author
11 Apr 2016 08:27
#720323
Update: Had a chance to install the OEM O ring this weekend. It was a better fit for sure, but was still tight. I was able to polish the drum area with my dremmel and got the fit near perfect.
The light that burns twice as bright, burns half as long. And you have burned so very, very brightly Roy.
