Carb installation
  • Sardonicus
  • Sardonicus's Avatar Topic Author
Re: Carb installation
05 Mar 2016 12:59
#713972
Well there goes that idea - off to eBay it is.
1976 KZ750 B1
  • GPzMOD750
  • GPzMOD750's Avatar
06 Mar 2016 05:11
#714072
What parts are you missing on your airbox? :You might be able to find replacements here or on ebay.
  • wrenchmonkey
  • wrenchmonkey's Avatar
06 Mar 2016 06:00
#714084
Yeah, I've always liked the look of the pods behind the carbs. Kinda' like velocity stacks on a muscle car but geez the headaches of having to retune the whole dang rig and possibly multiple times before you get it "right"... Suddenly that ol' stock air box looks mighty cool too!
BTW, the air box may have "L" shaped brackets to secure the box to the frame (behind the side covers). My 550 does. Loosening those L brackets or temporarily removing them will let you slip the air box backwards, away from intake manifolds and give you a little more wiggle room. I got that tip from another member here just *after* I struggled for what felt like hours installing my cleaned carbs.
Now I have to take them back out because it seems those pesky old intake boots/manifolds are leaky. A set from Z1 cost me a Benjamin but at least he had them (couldn't find any on ebay 'cept used ones), soft and new, made in Japan even and with vacuum ports for sync later.. woot!
  • Sardonicus
06 Mar 2016 15:11
#714172
looks like I'm missing just the connector tube dealy-os that go from the box to the carbs. looks like ebayers want no less than 20$ a piece for the tubes - found a complete airbox assembly for 40 - I'll take what I need from it and probably put it back up
1976 KZ750 B1
  • rrsmsw9999
  • rrsmsw9999's Avatar
06 Mar 2016 15:58
#714182
You can buy the air hose new for $40 from Z1. Also, the air box can be moved UP, not just back and you get a better area to stuff the carbs in. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • GPzMOD750
06 Mar 2016 17:52
#714198
You dint want old and crusty boots. They might leak and they're more like hard plastic than rubber which makes carb installation even harder.
