Carb installation
  • Sardonicus
  • Sardonicus's Avatar Topic Author
Carb installation
02 Mar 2016 14:53
#713502
I am working on a 76 kz750 - is there a trick to installing these carbs? I can't seem to get them to slide into the rubber part on the engine. Someone took them off before I bought the bike so i dont know if there is more to it than just a slip on deal.
1976 KZ750 B1
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carb installation
02 Mar 2016 14:59
#713504
They should be snug. If they've been off for a while you may need to grease them.
  • Sardonicus
05 Mar 2016 03:05
#713903
Another question about these carbs. Does a line have to go on this fitting, and where does it go?
1976 KZ750 B1
  • martin_csr
  • martin_csr's Avatar
05 Mar 2016 08:19 - 05 Mar 2016 08:20
#713931
That's the fuel overflow port. tubing should be installed so that fuel will be directed away from a hot engine, such as when a carb float malfunctions or after a crash. route the tubing behind the engine, forward of the swing arm & away from the chain & mufflers. some models have a little hose guide to keep the tubing in place.
As for installing the carburetors, make sure the carb holder clamps are floppy loose. also, if the rubber is hard, you may need to replace them. liquid wrench silicone spray lubricant is handy.
Last edit: 05 Mar 2016 08:20 by martin_csr.
  • Sardonicus
05 Mar 2016 09:21
#713940
Thank you very much for the info. With any luck I will Have it running tonight.
1976 KZ750 B1
  • GPzMOD750
  • GPzMOD750's Avatar
05 Mar 2016 09:32
#713945
If It were me I'd get new boots unless you know they aren't too old already, The rubber dries out, hardens and get microscopic (or bigger) cracks that cause vacuum leaks both in the body and where they mate with the head. Same goes for the airbox boots if you are still using it. I put a fresh set of airbox boots on my bike yesterday and it was amazing how much easier the carbs were to reinstall
  • Sardonicus
05 Mar 2016 09:46
#713947
I am missing parts for the air box so I will likely not be using it. I'll have a hard look at the rubber later. Can't imagine replacements could cost that much. In all likelihood the ones on it are original equipment
1976 KZ750 B1
  • TexasKZ
  • TexasKZ's Avatar
05 Mar 2016 10:01 - 05 Mar 2016 10:05
#713950
If you are not going to run the air box, you will become a pro at installing, removing, rejetting and adjusting the carbs. Try putting the words "pod filters" in the search box on this forum and spend some time reading.
Last edit: 05 Mar 2016 10:05 by TexasKZ.
  • GPzMOD750
05 Mar 2016 10:02
#713951
Sardonicus wrote: I am missing parts for the air box so I will likely not be using it. I'll have a hard look at the rubber later. Can't imagine replacements could cost that much. In all likelihood the ones on it are original equipment
You can get full sets off ebay for less than $100.
  • Sardonicus
05 Mar 2016 11:40
#713959
Clamp on filters will probably cost about $20. I may go back later and bring things back to stock because I think it looks cool just the way it was meant to look but for now this is a really low budget project. My goal is to get it road worthy for under a grand and I think it's doable. Tires will be a big expense. Not sure yet which tires I'm getting but seems like no matter what I choose it's not happening under 250.
1976 KZ750 B1
  • theApehouse
  • theApehouse's Avatar
05 Mar 2016 12:19
#713965
If you're talking about switching from the original airbox to clamp on air pod filters, I suspect it will give you carburetor issues as they are designed(and jetted) for the original airbox. Changing the amount, and force, of air/vacuum/suction in the system will most likely require different needs from the carburetor.
1987 KZ1000P, dynatek 2.2 coils
www.youtube.com/channel/UC3VtY1XWwKH3zK2trI2Hz1w
05 Mar 2016 12:31
#713967
Break out your checkbook if you plan to put pods on those CV carbs. The $20 for the pods will only be the ante to get in the game. You'll also need the parts required for re-jetting, and the odds are pretty slim that you will get a set on the first try that makes the bike run halfway decent. Of course, if you want it to run as well with pods as it did from the factory you may be in for a long wait and more $$$. ;) Ed
