Fuel Leak
  • John_KZ650
  • John_KZ650's Avatar Topic Author
Fuel Leak
28 Feb 2016 13:19
#712894
Hey Guys,
Looking for some tips here. Any advice would be greatly appreciated!
I bought this 1979 KZ650 last August and since then I've been conducting some maintenance on it. It's my first bike and I have little experience so you could say I'm a novice. I bought it running but for one reason or another it wouldn't start anymore a couple weeks later. Since then I've:
-changed the oil/filter
-new fuel filter
-checked electrical = new ignition coil (right one was busted)
-took off the carbs and cleaned them up
FYI: I've been using a Clymer manual along with whatever information I can find on the web
The issue I'm wondering about here happened after after I put the carburetor back onto the bike. I came in the next day and found a huge fuel puddle underneath. Upon further inspection I saw that not only was the fuel leaking from the drain hoses attached to the float bowls but also somehow going through into the air box and leaking out through its drain hose as well[reference pic].
I did my best to re assemble my carburetor back to exactly how it was when I took it off but I must have messed something up.
Has anyone ran through this before?
Thanks!
-John
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Fuel Leak
28 Feb 2016 13:36
#712900
Many times. Search Clear tube test.
The following user(s) said Thank You: John_KZ650
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Fuel Leak
28 Feb 2016 13:53
#712907
your carb is like a toilet bowl. The worn out flapper lets the water keep draing out. Fix the flapper, then you want to go all pro, set the height. if it was running fine before, the height maybe good already. But the flapper needs some help.
Re: Fuel Leak
28 Feb 2016 15:21
#712928
Olajoe - Your carb has flappers? :blink: What kind of bike is that? The KZ650 does not has such things.
John_KZ650 Is it possible you installed the floats upside down? I've read of this happening to folks. Ed
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Fuel Leak
28 Feb 2016 15:41
#712931
Ed i never said your carb has a flapper or that these carbs have flappers ;) Why the hypersensitivty? it's an analogy. How can you put a float on backwards that's not even possible and if by some chance that happened it wouldn't leak because it would already be in the closed position unless as pointed early in the analogy it would need to be cleaned or replaced.
  • John_KZ650
Re: Fuel Leak
28 Feb 2016 15:55
#712936
Clear tube test. Got it.
Thanks!
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Fuel Leak
28 Feb 2016 15:58
#712939
They can be installed upside down.
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Fuel Leak
28 Feb 2016 16:00
#712940
First time posting, what is this? Is this how you get guys to help out then flame them?
All you have to do is take the fuel line and blow through it, done. Tighten bowl gasket. You cannot learn about carbs by somebody telling you what to do and if this is the flame game, oh boy.
  • John_KZ650
Re: Fuel Leak
28 Feb 2016 16:05
#712944
Olajoe wrote: your carb is like a toilet bowl. The worn out flapper lets the water keep draing out. Fix the flapper, then you want to go all pro, set the height. if it was running fine before, the height maybe good already. But the flapper needs some help.
Yeah actually my buddy who is taking his Honda apart came over with his carb and we were comparing them. Saw that he had flappers but mine did not. Surprise to me.
-John
Re: Fuel Leak
28 Feb 2016 16:18
#712946
Olajoe wrote: Ed i never said your carb has a flapper or that these carbs have flappers ;) Why the hypersensitivty? it's an analogy. How can you put a float on backwards that's not even possible and if by some chance that happened it wouldn't leak because it would already be in the closed position unless as pointed early in the analogy it would need to be cleaned or replaced.
No hypersensitivty on my part. You stated "... the height maybe good already. But the flapper needs some help." To me that sounds like you are saying the flapper needs some help, and since the original posting is about carbs I asked what flapper you were referring to. Suggesting to the original poster that the "flapper needs some help" didn't come across to me as an analogy, but maybe I simply didn't understand your point.
As far as a float being put on upside down (I did not say "backwards" as you stated) actually, the float CAN be put on upside down. Folks have done it and it caused overflow problems. Ed
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Fuel Leak
28 Feb 2016 16:19
#712947
take pictures and write this stuff down. This way you can always have something later on for reference.
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Fuel Leak
28 Feb 2016 16:21
#712948
-John
