Fuel leak, NO overflow.
  • shamal
  • shamal's Avatar Topic Author
05 Feb 2016 11:14
#709551
:dry: how is this possibile? I noticed a small gas leak, a drop, under the #1 intake boot. Just between the boot and the head.
Carbs are fine. No running problems. No overflow. :S
1983 kz 550 h
  • shamal
Re: Fuel leak, NO overflow.
05 Feb 2016 11:25
#709556
To be more accurate the bike is running great.
I can rule any vacuum leak
1983 kz 550 h
05 Feb 2016 16:26 - 05 Feb 2016 16:27
#709630
Make/model??
Vac to petcock off #1??
Good Fortune! :)
Last edit: 05 Feb 2016 16:27 by Patton.
  • shamal
05 Feb 2016 20:51
#709658
83 gpz550h
Vacuum petcock disabled.
I just use PRI position, and when the ignition switch is off a 12volts magnetic valve on the fuel line is closed.
1983 kz 550 h
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Feb 2016 03:31
#709668
Magnetic valve? Pics?
  • jdvorchak
  • jdvorchak's Avatar
06 Feb 2016 04:26
#709676
You say vacuum petcock is disabled but do you still have the vacuum line running from #1 to the petcock?
and if it is really leaking gas between the cylinder head and the boot, you have a vacuum leak. If gas is getting through then so is air.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Feb 2016 04:31
#709678
You're right, I'm still stuck on the magnetic valve. Does it have a fuel gauge?
06 Feb 2016 04:32
#709679
shamal wrote: 83 gpz550h
Hopefully, there isn't an unused vacuum hose attached to the #1 carb holder.
Hopefully, the vacuum nipple is capped/plugged on the #1 carb holder.
Pods or stock airbox?
Good Fortune! :)
  • jdvorchak
06 Feb 2016 04:33
#709681
My guess is that the float on #1 is seeping or stuck and allowing too much fuel in the bowl.
John
83 KZ550M1
83 KZ1100LTD
Also own:
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Feb 2016 04:36
#709682
I'm betting on a leaky petcock.
06 Feb 2016 04:39 - 06 Feb 2016 05:22
#709683
Has the clear tube test been performed on #1 carb to assure that the fuel level is within specs and not too high?
Here, for reference , is the stock vacuum operated petcock:
Why was the petcock's vacuum function abandoned in favor of a magnetic valve?
Good Fortune! :)
Last edit: 06 Feb 2016 05:22 by Patton.
  • strum
  • strum's Avatar
06 Feb 2016 04:43
#709685
Yeah when you say vacuum disabled and just using prime. then all you have to depend on to hold fuel back is the float needles.
I betting on a seeping needle and I agree with the past statement. if fuel is getting out then air is getting in.
This exactly why i went with a manual petcock.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
