Need info on Carbs
  • redhawk4
  • redhawk4's Avatar
Re: Need info on Carbs
31 Dec 2015 08:52 - 31 Dec 2015 08:54
#705027
Everything looks like my 28mm pumpers off a 1980 model other than the one float bowl and like I say that could be swapped over very easily, in fact there was a thread on here just recently where someone was asking about doing that very thing on some 28's because that second pump gave a longer duration to the enrichment.
The needle number may also give you a clue as to what the carbs came off originally, that's how I worked out what mine were because the needle number was for the 1980 28mm pumper carb and all the other details of the carb matched with that.
From the pictures it looks like the nozzles are missing on two of the carbs where the fuel is sprayed in to the intakes.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 31 Dec 2015 08:54 by redhawk4.
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Dec 2015 09:51
#705035
I'm looking for a pump that bolts on. Any ideas?
