Need info on Carbs
- spdygon
Need info on Carbs
29 Dec 2015 17:47
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- floivanus
Re: Need info on Carbs
29 Dec 2015 18:28
Vm26ss from a 79ltd? What size are the throats?
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Nebr_Rex
29 Dec 2015 18:29
26 or 28mm pumper carbs. Only 1 pump, it has the lever.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- floivanus
29 Dec 2015 18:30
The triangle cover isn't on the 28 pumpers just open space
Andrew
Andrew
- spdygon
30 Dec 2015 15:25
They are 28mm .
And meant two diaghrams
They're not mine but a friends.
1974 Z1 900 project
1974 Z1 900 project
- strum
30 Dec 2015 15:57
Canadian 28mm possibly
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
- strum
30 Dec 2015 16:01
I have seen the extra diaphragm on the canada pumper models but not sure about the double fuel inlets do you have a pic of the bore side
Blairsville Ga.
- spdygon
30 Dec 2015 16:16
Don't have a pic but friend says it measures 28.70
1974 Z1 900 project
1974 Z1 900 project
- strum
30 Dec 2015 16:29is your friends name mark?spdygon wrote: Don't have a pic but friend says it measures 28.70
Blairsville Ga.
- strum
31 Dec 2015 04:27
check out this link. This leads me to belive those carbs are vm 26mm off a 79 LTD
kzrider.com/archive/viewthread.php?tid=29912
Blairsville Ga.
- redhawk4
31 Dec 2015 08:17 - 31 Dec 2015 08:24
So many parts are interchangeable, that it's possible these are not as they came on the bike from the factory. I have a set of 28mm carbs on my KZ1000A2 that have the single accelerator pump that came from a 1980, however if I swapped the float bowls from my 24mm double pumper carbs that came from a KZ650 then I would have carbs that loo like yours, including the dual fuel inlets..
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 31 Dec 2015 08:24 by redhawk4.
- spdygon
31 Dec 2015 08:33
Don't know....all I know is that my friend bout this thinking that they were 28mm pumpers.
Normally they have single fuel inlet , one diaphragm and the idle screw on the bottom.
This measure 28.70 on the head side , have two fuel inlets , two diaphragms and te idle screw is on top.
1974 Z1 900 project
1974 Z1 900 project
