Carb help 1983 kz 550m ltd
- fastdave
28 Dec 2015 12:51
Help needed with these carb hoses:
And these:
My questions are color coded. I think that something should go to the vaccum petcock. Thanks ahead of time.
And these:
Attachment 20141201_190058_kindlephoto-141554842.jpg not found
Faster is more fun
- fastdave
Re: Carb help 1983 kz 550m ltd
28 Dec 2015 12:52
And what to do with these hoses??
Attachment 20141201_190044_kindlephoto-140549949.jpg not found
Faster is more fun
28 Dec 2015 13:13
Yellow- vacuum, petcock, air injection, one capped.
Blue- vents
Red=fuel
Blue- vents
Red=fuel
- fastdave
28 Dec 2015 13:41
Could you please be more specific. Which specifically goes where? There are four yellow. I am not planning on reusing the air induction thing.
Any help would be greatly appreciated. I have been trying to figure this out for hours. Thank you
Attachment 20141130_093053_kindlephoto-142793609.jpg not found
Faster is more fun
28 Dec 2015 13:57
Put plugs on three and use one for the petcock.
Have a manual?
Have a manual?
- fastdave
28 Dec 2015 14:21
Do the blue lines connect to anything
Faster is more fun
- mopguy
28 Dec 2015 14:36 - 28 Dec 2015 16:14
I do not have blue on mine. the yellow lines are plugged at #1,#3,and #4 with caps, and #2 receives vacuum from the petcock.
Last edit: 28 Dec 2015 16:14 by mopguy. Reason: made a mistake
28 Dec 2015 15:15
The blue lines are vents, they usually go above the air cleaner. Manual?
The following user(s) said Thank You: fastdave
- Bahlzeron
28 Dec 2015 15:45
As swest stated, Red is fuel line, blue are overflows, the two vacuum with T fitting are for emissions crap, the other vacuum goes to petcock. If you are eliminating the emissions junk, the two with the T can be removed and need to be capped off, so does the hole in the air box where the emissions stuff dumps into, as well as the two holes on the cam cover. Pickup a factory service manual (it will save a lot of headaches), you can get em from ebay for a decent price.
'83 kz550 LTD (shaft)
- loudhvx
28 Dec 2015 16:03 - 28 Dec 2015 16:06
Blue are not overflow. Blue are bowl vents. They go up and just stay open near the airbox. Do not let them get into turbulent air as that will affect fuel flow by altering bowl pressure.
The overflows are on the bottoms of the bowls.
Red is fuel inlet.
If you are not using the fresh-air-suction system, then cap off three of the yellows. One of the yellows goes to the vacuum petcock.
I have a few manuals in my sig, but not a factory specific manual for the M. However, you can use the factory manuals I have for the 82/83 H1/H2 (gpz) models as they use the same (almost the same) carbs.
Red is fuel inlet.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 28 Dec 2015 16:06 by loudhvx.
- fastdave
28 Dec 2015 23:20
Thanks guys. I do have manuals. They are confusing. There are updates for years 82,83,84. They are very hard to find what your looking for and the pictures are terrible. Oh well. Also I have the kz550m ltd model which has been making it harder.
Before:
Now:
Before:
Attachment 20141128_1621041.jpg not found
Now:
Faster is more fun
- jdvorchak
30 Dec 2015 07:31
I have a question or maybe just an observation. He said he is not using the vacuum operated crank vent that leads to the air box. Big hose. If he does away with that shouldn't he also use a small crankcase filter so the case vents? I don't think you want to cap that off or leave it open.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
