Carb help 1983 kz 550m ltd
  • TexasKZ
  • TexasKZ's Avatar
Re: Carb help 1983 kz 550m ltd
30 Dec 2015 07:39
#704906
The big hose in his pic is not the crankcase vent, it is the clean air system that introduces filtered outside air into the exhaust ports. The crankcase vent has a much smaller hose going from the separator on top of the transmission to the air box. You are right that it should not be capped. Many folks install a small filter, while others run a longer hose either toward the ground in front of the swingarm, or toward the rear of the bike under the tail piece.
