Mikuni Kogyo Carb identification
- kawasakisubaru
12 Dec 2015 16:16
I need help i identifying these carbs.
I know they're mikuni, but I can't find anything on kogyo model carbs.
As you can see a few of the parts are rusted and wearing so i wanted to buy a rebuild kit.
But they look nothing like what I found on the mikuni website
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- kawasakisubaru
Re: Mikuni Kogyo Carb identification
12 Dec 2015 16:17
forgot to add pic lol
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
12 Dec 2015 16:25 - 12 Dec 2015 16:26
I think what you have there are the very desirable smoothbore carbs. Take a look in the rectangular depression I circled in yellow in the first image below. If there is a little brass bead in there as I show circled in red in the second image below I believe that proves for sure that they are in fact smoothbores. That's a good thing! Ed
Attachment 00003b-41.jpg not found
Attachment Smoothbore-2.jpg not found
Last edit: 12 Dec 2015 16:26 by 650ed.
The following user(s) said Thank You: kawasakisubaru, 750Kruzer
- zukdave
12 Dec 2015 18:02
Ed's correct they are VM29 smoothbore there are no rebuild kits for them you will need to get each part separate
Call Rob at Z1 Enterprize he'll get you what you need.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawasakisubaru
12 Dec 2015 21:33
thanks guys, checked for that little bead and its there.
Whats so special about these carbs? they work great, but recently have shown some shaky throttle responses at low speed
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- floivanus
12 Dec 2015 23:51
Aftermarket performance carb, bigger venturi, bigger fuel passages, extra parts. Smoothbore design.
Good carb for the day, bit of a step up over 26's
Past; 78 kz1000, 83 kz550
Andrew
Andrew
13 Dec 2015 03:17
No eBay APP ID and/or Cert ID defined in Kunena configurationJust for laughs let's say you wanted to replace them.....
- zukdave
13 Dec 2015 03:40
Since I run these on my 810 cc GPz750 motor let me say this
sell them they are a RACE carb and way to big for a stock street riden KZ650.
you will pull your hair out trying to get them to idle and have good off idle perfomance.
To give you an idea I'm running 25 pilot jet and 125 main jets and it still idles like shit under 1200 rpms
if at all and get's sht for gas milage
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawasakisubaru
13 Dec 2015 06:00
(My bike is KZ750 E1 with a stock motor and aftermarket exhaust)
Well that explains a lot! I bought the bike two years ago and it has ALWAYS had minor idle issues. The guy I bought it from bought it from the original owner and got it running to resell.
Redline cycles in Illinois wants $80 an hour for a rebuild/refurbish. But with shipping and labor and parts I suspect I'm better off buying another set of carbs.
Any recommendations? Everything from dime city cycles is hella expensive
(Also 650ed your link is not working)
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
13 Dec 2015 06:05
I don't know why the link didn't work, but here's what it was to:
Attachment 00003a-143.jpg not found
- kawasakisubaru
13 Dec 2015 06:08
LOL $1,200????? That's insane
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
13 Dec 2015 06:36
They are very desirable carbs, but they are a bit large for a stock KZ750 engine. Treat them very carefully if you decide to put smaller carbs on your KZ750. Ed
