Mikuni Kogyo Carb identification
Re: Mikuni Kogyo Carb identification
13 Dec 2015 12:53Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- kawasakisubaru
13 Dec 2015 13:01
Thanks for all this info, I'm learning a shit ton about these carbs/how they work and it seems the most cost effective plan as of now is to buy larger main jets and pilot jets. Assuming factory jets, what sizes would I need to smooth out the idle?
(Good gas mileage would be nice but fuck it, I didn't buy a motorcycle 11 years older than myself to be economical)
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- zukdave
13 Dec 2015 13:18
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- floivanus
13 Dec 2015 13:38Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- 750Kruzer
13 Dec 2015 14:05 - 13 Dec 2015 14:07
What does the "BS" & "CV" designations stand for?
floivanus wrote: Honestly, I don't really understand the hype, back in the 70's when they came out the 29s were a great carb. Today, there are very few bikes that come with mechanical carburetors, CV carbs dominate the market, even on crotch rockets etc. well, that is, before EFI.
$600 seems to be real world top dollar for smoothbores. Someone once in a while may get more, but it's not typical
1983 KZ750 LTD Twin K1
Last edit: 13 Dec 2015 14:07 by 750Kruzer.
13 Dec 2015 14:06 - 13 Dec 2015 14:07
floivanus wrote: "Seems $500-600 is the midrange for them."
Agree. Ed
Agree. Ed
Last edit: 13 Dec 2015 14:07 by 650ed.
- floivanus
13 Dec 2015 14:17
CV carbs are controlled by vacuum signal from the engine, they work much like the old quadrajet or edelbrock carbs.
You may crank the theottle wide open, but if the engine only needs 3/4 throttle the slide only really moves 3/4 of the way, reducing bogging, increasing gas mileage and performance. If you look at motorcycles, minus the aftermarket performance carbs, the mechanical slide type carbs basically disapeared in the 1980s and were replaced with CV carbs.
BS carbs are a subset of mikuni carbs that came on KZ and GS suzuki models. I.e; BS34 carbs on kz1000s after 1981.
Past; 78 kz1000, 83 kz550
Andrew
Andrew
The following user(s) said Thank You: 750Kruzer
13 Dec 2015 14:19 - 13 Dec 2015 14:20750Kruzer wrote: What does the "BS" & "CV" designations stand for?
CV = constant vacuum.
BS is Mikuni's designation for a family of CV carbs from back in the KZ era. BS34's for example are 34mm CV carbs.
Edit: looks like two of us posted at the same time. :side:
Last edit: 13 Dec 2015 14:20 by Nessism.
14 Dec 2015 05:46
Link works fine for me, using desktop with Windows7.
650ed wrote: Just for laughs let's say you wanted to replace them.....
