How Many Turns for the Idle Mixing Screws on KZP?
- bl_francis
15 Nov 2015 11:12
1987 Kawasaki KZ1000 Police - Idle Mixture Screw (or fuel screw?)
From what I can see in my Clymer manual these are sealed at the factory with a metal cap for the US models but does anyone know how many turns these should have?
My mechanic is working on my bike right now and it is running rich when it's cold outside. Spark plugs are black, etc.
#3 in diagram below \/
Thanks in advance!
Attachment IMG_3228.jpg not found
Thanks in advance!
1987 KZ1000 Police
- DFIGPZ
Re: How Many Turns for the Idle Mixing Screws on KZP?
15 Nov 2015 12:06
I would start at 2 1/2 turns out.
1984 750 Turbo
The following user(s) said Thank You: bl_francis
- Jussumguy
15 Nov 2015 20:02
If we were tuning single cylinder bikes this would be pretty easy but there's four of them. I've read a couple service manuals and they get really vague when it comes to this topic. Just my opinion here, watch your tachometer and tweak the screws until the idle speed increases. (Warmed up engine of course) if anyone else has an answer please share. Good luck, it may take you a few sessions , I'm still adjusting mine. They're pretty close but I always feel like I've made things worse when I'm done.
Good luck, don't give up and report back when you get them right!
Rich
Rich
- ThatGPzGuy
16 Nov 2015 00:43
A Colortune is very helpful in adjusting the fuel screws.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- jackleberry
16 Nov 2015 07:44ThatGPzGuy wrote: A Colortune is very helpful in adjusting the fuel screws.
On a scale of one to ten, how helpful would you say it is? I have one and I would rate it at about a 2. Better than nothing, but not really helpful at all in terms of getting the mixtures dialed in for either best economy or best performance. Do you know something I don't?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- Jussumguy
16 Nov 2015 16:39
If you put a set of vacume gauges on and adjust the mixture screws till you get the greatest vacume , wouldn't that be the way to go about it? Then sink them and you're done ya? It's been a long time since auto class in high school!
- ThatGPzGuy
17 Nov 2015 01:51jackleberry wrote:ThatGPzGuy wrote: A Colortune is very helpful in adjusting the fuel screws.
Probably not. I have to compare it to what I used to do which was put them all at whatever I was told the factory setting was then try to figure out why I was getting a lean surge or had no power on top. With the Colortune I can back the screws out until it's running fat and then slowly dial it in until I see a nice blue flame. Is it tuning for maximum anything? Probably not, but since I did that with my GPz it has never run better.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- undiablo
17 Nov 2015 03:15 - 17 Nov 2015 03:17
I have discovered that optimal mixture screw setting were all diferrent in my kz750. Don“t remember precisely each one, but take this for example:
Cylinder 1 --> 2 1/2 turns
Cylinder 2 --> 2 3/4 turns
Cylinder 3 --> 2 turns
Cylinder 4 --> 2 1/4 turns
I have the Colortune, it is usefull. But I thinks is better to hear the RPM change when adjusting the misxture screw.
Bike have never ran better.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 17 Nov 2015 03:17 by undiablo.
- jackleberry
17 Nov 2015 07:05Jussumguy wrote: If you put a set of vacume gauges on and adjust the mixture screws till you get the greatest vacume , wouldn't that be the way to go about it? Then sink them and you're done ya? It's been a long time since auto class in high school!
Yeah, that works too and is the most accurate way I've found to do it without an EGA. However, it's still a situation where you have like a 1/4 to 1/2 a turn range where the vacuum reading is the same (just due to the sensitivity of the measurement ) but the mixture (and performance) is not. So you're still left just 'in the ballpark' of the correct settings.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- Jussumguy
17 Nov 2015 16:41
Hi jackal berry
The story I read said to get max vacume and then turn the screws in about a 1/4 turn and call it good. I'm excited and want to do my carbs again!
Crazy!!!
Crazy!!!
- redhawk4
17 Nov 2015 17:09 - 17 Nov 2015 17:11
Getting the highest vacuum is a tried and tested method of setting the idle mixture. One thing to be aware of is if you have air screws, or ones that control fuel flow, when giving it that final tweak, I believe that should be an 1/8 or 1/4 turn to the richer, from maximum vacuum, which would be turning air screws in and turning them out if the screw controls the air flow. I have bikes with both these types of carb setup, so have to be careful to think what I'm actually doing when I make adjustments or I can find myself wondering why it's doing the opposite of what I expected when I turn the screw. The downfall of using vacuum gauges is when you use the damping screws to get a steady reading, it also makes them slow to respond to small changes, so you need to use as little damping as you can and move the screw a little, and then wait to see what happens with the vacuum.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 17 Nov 2015 17:11 by redhawk4.
24 Mar 2016 08:28
Get the screws in the ball park. 1 1/2- 1 1/4 etc. Adjust in small increments in/out 1/8 turn each time. Wait ten seconds for the carb to catch up then try again until best idle. I then raise the RPM's to about 2800 and listen for a miss and dial it out if I can.
