How do I fix this stripped out jet?
- DobbinsCMA
03 Oct 2015 07:59 - 03 Oct 2015 09:49
Seems they used the wrong size flat head. Now it's all mangled. Do I cut a new spot for the flathead?
Attachment image-48.jpg not found
Attachment image-49.jpg not found
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
Last edit: 03 Oct 2015 09:49 by KZQ. Reason: Title not searchable.
Re: How do I fix this?
03 Oct 2015 08:11 - 03 Oct 2015 08:12
Dremel with a cut off disc to cut a new slot? Make sure your new slot matches your screwdriver for a nice tight fit. I'd heat the carb body and use a little PB Blaster around the threads too.
Last edit: 03 Oct 2015 08:12 by Nessism.
- DobbinsCMA
03 Oct 2015 08:20
Yah the others came out but I think they stared to clean them and f'ed up and quit. Where would I order new ones?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- pete greek1
03 Oct 2015 08:48Try calling hereDobbinsCMA wrote: Yah the others came out but I think they stared to clean them and f'ed up and quit. Where would I order new ones?
www.google.com/url?sa=t&rct=j&q=&esrc=s&...m=bv.104317490,d.cWw
Pete
- DobbinsCMA
03 Oct 2015 10:00
Yah I looked. They don't carry any replacements for them. Seems these are hard carbs to find parts for.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- pete greek1
03 Oct 2015 10:38I needed a part for some carbs yrs. ago & didn''t see it on their website, so I called them, & they said they didn't have any new ones but they have many old carbs & he said he would check & see if he could find what I was looking for & he would call me back, the next day I got a call back saying he found the part I was looking for,DobbinsCMA wrote: Yah I looked. They don't carry any replacements for them. Seems these are hard carbs to find parts for.
Pete
The following user(s) said Thank You: DobbinsCMA
03 Oct 2015 11:15
Did you try cleaning it out with a guitar string?
- DobbinsCMA
03 Oct 2015 11:59
Good idea!
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
03 Oct 2015 12:08 - 03 Oct 2015 12:09
No eBay APP ID and/or Cert ID defined in Kunena configurationI won't disturb them if I don't have to. I ordered reverse drills just for this kind of problem. Should be getting them today.
Last edit: 03 Oct 2015 12:09 by SWest.
- jdvorchak
Re: How do I fix this stripped out jet?
04 Oct 2015 03:27
Just my 2 cents worth. Those left hand drill bits are great for steel screws/bolts but I'm afraid all they will do is drill a hole in that brass jet. If it were my bike I'd try to clean it first with a guitar string, as others have suggested, or grab the top part with some vice grips and try to remove it. I find that once clamped onto the fastener a tap with my hand works better than trying to muscle the screw out.
Now drilling or using the vice grips would be a last resort and ONLY after I have sourced the replacement jet.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
04 Oct 2015 03:33
That's why I suggested the guitar string. Some pilot jets have emulators that can get clogged. It has to be removed. All the suggestions above are right. The drills ARE a last resort.
- jakedude
04 Oct 2015 05:03
If the guitar string does not do it for you, I would use a small easy out to extract the jet.
www.craftsman.com/p/p-00966196000P?sid=I...000&kpid=00966196000
Nothing lasts, nothing is finished, and nothing is perfect.
