NooB needs some Float Level checking advice ...
  • Mean Green Z28
  • Mean Green Z28's Avatar Topic Author
  • Kawasaki NooB
Re: Re:NooB needs some Float Level checking advice ...
16 Oct 2015 13:50
#694789
Thanks!
2010 Camaro 2SS
1983 Kawi KZ1000P ... bag of bolts
  • Mean Green Z28
  • Kawasaki NooB
24 Oct 2015 13:19
#695775
Well I got an air box and the ducts ... it's not gonna fit hahaha. Since he plan was to use the pods (before I realized what a pain in the ass they are to tune) I put all the electronics/wiring where the box would usually sit. Ugh, I'm gonna try my best to not start hacking at everything again. I may have to drop the battery down a few inches and put all the wiring in a tray above it if I was to use the air box.
2010 Camaro 2SS
  • Mean Green Z28
  • Kawasaki NooB
24 Oct 2015 13:22
#695776
May have to rethink a lot if I use rhe air box again... or well, more fab time
2010 Camaro 2SS
  • Mean Green Z28
  • Kawasaki NooB
28 Oct 2015 03:50
#696243
Well Z1Enterprises is taking MUCH MUCH longer than I expected to ship my order. Should have just split my order between them and other companies before I ordered. In the mean time, I'm moving the coil packs from under the seat to the stock location; gonna have to make some mounts.
2010 Camaro 2SS
  • jackleberry
  • jackleberry's Avatar
Re: NooB needs some Float Level checking advice ...
28 Oct 2015 07:52
#696277
Having that airbox will be worth the trouble!
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • pete greek1
  • pete greek1's Avatar
28 Oct 2015 10:34
#696304
Mean Green Z28 wrote: Well I got an air box and the ducts ... it's not gonna fit hahaha. Since he plan was to use the pods (before I realized what a pain in the ass they are to tune) I put all the electronics/wiring where the box would usually sit. Ugh, I'm gonna try my best to not start hacking at everything again. I may have to drop the battery down a few inches and put all the wiring in a tray above it if I was to use the air box.
Or you can spend about 150.00 on a Shorai Li/Ion battery , which is about the size of a pack of cigarettes , & can be mounted in any position, sideways/ upside down, ETC.
Pete
  • Mean Green Z28
  • Kawasaki NooB
28 Oct 2015 14:07
#696332
Just a bit of moving around to accommodate the air box ... actually everything moved around haha. The coil packs went back to their original area above engine; had to make mounting brackets all over again for everything.
A bit of background ... previous owner cut off EVERYTHING!!!
2010 Camaro 2SS
  • Mean Green Z28
  • Kawasaki NooB
02 Dec 2015 11:34 - 03 Dec 2015 18:53
#701591
She runs!
2010 Camaro 2SS
Last edit: 03 Dec 2015 18:53 by Mean Green Z28.
