- Thank you received: 1
OEM carburetor
- oldie
Thanks.
- Thank you received: 2756
- mike1957
- Thank you received: 8
for a 1980 kz 250 .Most likely the same as a 1982 kz 250 C
www.bikez.com/motorcycles/kawasaki_kz_250_ltd_1980.php
mike1957
- Thank you received: 2829
- oldie
- gd4now
- Denco where did you go?
- Thank you received: 441
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
gd4now wrote: The FSM I have covers the z250 and z305 bikes and it has listings for the 82 250A4 and B3 models but not the LTD model. It indicates that both of those models came stock with 2 Kihein CV32 carbs
Those would be the 2-cylinder KZ250 models. The LTD (KZ250-C) is the single cylinder model. Ed
- oldie
- oldie
- oldie
- Tyrell Corp
- Thank you received: 261
needle valve assembly- usually available as a pattern part in a carb rebuild kit.
Diapragm - expensive, this is who I use www.nrp-carbs.co.uk
Float - that might take some searching
Maybe cheaper to see if you can find a spare set, the CV 32's were on the 600 water cooled Ninjas too.
