Q: jet OEM nr.
- missionkz
Re: Q: jet OEM nr.
03 Jul 2015 09:58
Any decent machine shop, tools supplier will stock or have access to, drill bits that are so tiny, they're thinner than a cat whisker
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- yeekim
Re: Q: jet OEM nr.
03 Jul 2015 12:13missionkz wrote: Any decent machine shop, tools supplier will stock or have access to, drill bits that are so tiny, they're thinner than a cat whisker
:laugh:
Damn, I don't have a cat, will the dog work :S
Ex nihilo nihil fit!
- missionkz
Re: Q: jet OEM nr.
03 Jul 2015 12:25 - 03 Jul 2015 12:30
No eBay APP ID and/or Cert ID defined in Kunena configurationMaybe something like this:
www.cmlsupply.com/mini-micro-drill-bit-s...XWv8YCFQeBaQodvkMOaw
www.gearhob.com/eng/design/drill_eng.htm
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 03 Jul 2015 12:30 by missionkz.
- undiablo
Re: Q: jet OEM nr.
03 Jul 2015 13:22 - 03 Jul 2015 13:26
may be.... I think ....
may be you did find #38 slow pilot jets for the Keihins CV34.....
Attachment 35slowjetvs.jpeg not found
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 03 Jul 2015 13:26 by undiablo.
Re: Q: jet OEM nr.
03 Jul 2015 14:44yeekim wrote: Yes, it's a MIKUNI on that link.
This drill is a bit big I think :S :S
I need #40 but on that set is the smallest #60.
Or is the flow rate on the jet, not the size?
No 81 is the smallest.
- missionkz
Re: Q: jet OEM nr.
04 Jul 2015 11:07
With less experience, he might think the large number means large diameter.... just thinkin' outloud.
Bruce
1977 KZ1000A1
1977 KZ1000A1
Re: Q: jet OEM nr.
04 Jul 2015 11:14
+1. For number drills, the larger the number, the smaller the hole.
- yeekim
Re: Q: jet OEM nr.
04 Jul 2015 11:20
Shame on me :blush: :blush: :blush:
But what is equivalent for #40 jet?
Once again: on KEIHIN jets
it's a size of hole ?
it's a flow rate?
it's a flow rate?
Re: Q: jet OEM nr.
04 Jul 2015 11:54
Yeah it would be too easy that way. I went down to 60's on my Mics. Still too rich. Not by much. I'll wait until I put in my 10.25/1's before I F with it anymore. For the price it was worth having them. It looks like they go down two sizes in between 60 and 6.5. That's good, I should be able to find that "sweet spot".
- yeekim
Re: Q: jet OEM nr.
04 Jul 2015 13:11
Sorry, but is all that drill s**t metric, imperial or universal?
Re: Q: jet OEM nr.
04 Jul 2015 15:02
They appear to be in inches. There's another listing in metric but it doesn't help.
www.cmlsupply.com/mini-micro-drill-bit-s...1-80-pin-vise-combo/
