carb overflow problem
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: carb overflow problem
04 Apr 2015 18:35
#666578
My seat still leaked even after the Q tip method. The needle cleaned up nicely. I took a engineers pencil, shaved it so it would fut into tha seat bore, used fine valve lapping compound and made a new seat. It was that or order a new set but with 33 mm Miks, that's a crap shoot. It worked.
  • baldy110
  • baldy110's Avatar
05 Apr 2015 16:16
#666663
Zephyrrider wrote: When you do get it sorted slade park it on centerstand as much as possible - mine is always on it and looks like you have some good storage space - if you absolutely have to use side stand carry a small block of hard wood about 2 inches thick so bike is always as level as it can be :)
Why?
  • Zephyrrider
  • Zephyrrider's Avatar
05 Apr 2015 20:43
#666722
You are joking arent you ?
Mick
1994 ZR750 Zephyr C4.
  • baldy110
  • baldy110's Avatar
06 Apr 2015 16:24
#666854
No I'm not joking I would really like to know the reason for this.
  • spdygon
  • spdygon's Avatar
06 Apr 2015 18:15 - 06 Apr 2015 18:16
#666872
If u have ever had #1 or 2 spark plug fail...that's way.
I think
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 06 Apr 2015 18:16 by spdygon.
  • TexasKZ
  • TexasKZ's Avatar
06 Apr 2015 18:19
#666874
Maybe he needs the exercise??? :blink:
An awful lot of bikes seem to get along just fine without one, but what do I know?
  • baldy110
  • baldy110's Avatar
06 Apr 2015 19:08
#666886
spdygon wrote: If u have ever had #1 or 2 spark plug fail...that's way.
I think
OK what does spark plugs 1 and 2 have to do with the making sure to keep the bike level?
  • Zephyrrider
06 Apr 2015 22:01 - 07 Apr 2015 02:02
#666911
Seems you are on the wrong fucking post - no one is talking about plugs - this is about carbs
read it properly in the future before you make a brain dead comment
Mick
Last edit: 07 Apr 2015 02:02 by Zephyrrider.
07 Apr 2015 05:27 - 07 Apr 2015 05:42
#666922
Wow! :laugh: :laugh: :laugh:
I may be wrong, but believe the comment about plugs was related to carbs in that keeping the bike level may reduce the chance of the #1 and/or #2 spark plugs from fouling from too much fuel if the bike is left on the side stand when there is a problem with the float valves and/or petcock. The theory being that the overflow fuel will end up in cylinders 1 & 2 since they are on the low side if the bike is on the side stand. Ed
Last edit: 07 Apr 2015 05:42 by 650ed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Apr 2015 05:37
#666924
Zephyrrider wrote: Seems you are on the wrong fucking post - no one is talking about plugs - this is about carbs
:woohoo:
  • Zephyrrider
07 Apr 2015 05:42 - 07 Apr 2015 05:55
#666928
At no time in this post were problems with plugs mentioned or asked about
I did not make reference to plug problems and i park my bike on centre stand as it may not get ridden for a few days and up to a week occassionly but a dam good idea all the time
Have no idea what they were on about - like i said - READ the post properly !
Mick
Last edit: 07 Apr 2015 05:55 by Zephyrrider.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Apr 2015 06:18
#666932
Deere in the head lights. He shouldn't have this problem at all if he would take the advice given. Sooty plugs on one side is a symptom of those carbs not being set right. Parking on the center stand is good practice if the bike won't be ridden for a while. Gas like water will find it's way in or out given enough time. It can also find it's way into the engine washing out the rings and filling the crank case with gas. The over flows are supposed to prevent this but sometimes they don't. I don't have them on my 33's. When I park the bike in the shed, it's always on the center stand.
The following user(s) said Thank You: Zephyrrider
