Anybody buy any NOT incredibly overpriced jets?
  • daren1093251
  • Topic Author
28 Dec 2014 12:51 #657196 by daren1093251
I'm back to square 1 with my '84 KZ550, it runs and all but my carbs needs new jets I tried cleaning them but the pilots are so bad after 24 hours of trying to soak them in these products : Acetone, carb cleaner, brake cleaner, WD-40, a machine that is used to rinse metal parts, I still cannot get my pilot unclogged. I tried to poke it out with a thin wire it won't budge, compressed air doesn't get it out, unless you guys have a suggestion OTHER than banging it with a hammer setting it on fire burning the hell out of it into molten metal please tell me.
Anywhom, I thought a nice carb kit would be nice until I see the price, 40$ for a single carb? Kinda very overpriced don't you think? It's impossible to just find the pilot jet (92064-1055) I found 1 for 30$ each and no, i'm not a really cheap person but that's all crazy overpriced.
If anybody knows somewhere to find at least a pilot jet for a normal decent price please, tell me i'm going crazy.
Thank you, a guy who is about to burn those little parts even thought it'll never melt.
If you ain't first ; You're last
Current bikes :
2013 Kawasaki KLX250s
1984 Kawasaki KZ550 LTD (Project!)
1985 Honda Aero 85 (Rebuilding!)
28 Dec 2014 13:26 #657199 by KZ Rat
Micro drills are pretty handy for cleaning out your existing jets-might be worth trying- lots of them on ebay and online-like this www.pjtool.com/20pcmicrodrillbitset.aspx...QmDpAOyT0aAs5r8P8HAQ
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
28 Dec 2014 13:29 #657200 by 650ed
Maybe these folks? Ed
www.jetsrus.com/
The following user(s) said Thank You: daren1093251
28 Dec 2014 13:55 #657203 by Zephyrrider
Replied by Zephyrrider on topic Anybody buy any NOT incredibly overpriced jets?
Last resort - welder tip cleaning wires.The smallest i have fits through nicely - .5 mm but they are not smooth so push the crap through once and leave it at that and then try wire guitar E string to get the rest of it out.
Have also used the very tiniest needle /pin with a small pair of pliers in the past to clean them but this is not recommended in case the needle/pin breaks. None of the products you used would shift that kind of deposit. Tried them as well.
Mick
1994 ZR750 Zephyr C4.
  • Motor Head
28 Dec 2014 14:18 - 28 Dec 2014 14:22 #657206 by Motor Head
Replied by Motor Head on topic Anybody buy any NOT incredibly overpriced jets?
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration4 kits for $80 shipped = $20 a carb and it shows new pilot jets.
Thats strange the ebay link is not showing. I'll just add the link and Item #.
It might be just my browser set up, ie addblock
Item # 191459329126
Last edit: 28 Dec 2014 14:22 by Motor Head.
28 Dec 2014 15:04 #657211 by bountyhunter
Replied by bountyhunter on topic Anybody buy any NOT incredibly overpriced jets?
Try an ultrasonic cleaner like they use on jewelry? Might work. Other thing is the old Berryman's Chem Dip for a week. That stuff eats almost anything including your skin.
28 Dec 2014 15:43 #657218 by !Seymore
Motor Head wrote: Thats strange the ebay link is not showing.
There was a recent update, on someones end, that broke this "feature". :blink:
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • daren1093251
  • Topic Author
28 Dec 2014 19:57 #657245 by daren1093251
Replied by daren1093251 on topic Anybody buy any NOT incredibly overpriced jets?
Thanks guys for all the input! I ended up ordering the 80$ suggested atleast everything will be new in there! Now we patiently wait. and wait some more.
P.S : I tried Acid today so far it's been about 8 hours maybe? and I looked at one of the jets and it's still clogged there, I really can't figure out what in the world got in there but it's bad! My big transport air compressed hooked right on to it can't push air through it! Crazy what can happen after being parked like 20 years in a shed.
Current bikes :
29 Dec 2014 06:27 #657261 by Old Man Rock
Replied by Old Man Rock on topic Anybody buy any NOT incredibly overpriced jets?
No eBay APP ID and/or Cert ID defined in Kunena configuration$80.. :pinch: Hopefully that's for all 4 carbs.
In case someone else needs.... Here's another @ $23 for one carb....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
29 Dec 2014 06:48 - 29 Dec 2014 06:54 #657263 by TexasKZ
I'd stay away from acid. It will eat away the brass and can ruin the tiny orifice you are trying to clear. If the clog is old fuel, the only acid that will dissolve it will likely eat the brass faster. What is needed is a strong solvent that will dissolve dried hydrocarbons and leave the brass alone.
If the clog is something else like a tiny chunk of rust or sand, chemistry may not be the answer. That's when the jet cleaner or guitar string comes into play. Be very careful, the hole is tiny and the brass is soft.
Last edit: 29 Dec 2014 06:54 by TexasKZ.
31 Dec 2014 16:28 #657483 by z1wiz
I wouldn't use a torch tip cleaner or micro drill because you can unintentionally make the holes larger than you want. (.002 larger on a pilot jet is quite a bit) I use pin gages starting at .011 and work my way up in size until its you can feel the gage is too big. This set goes from .011-.060 and can be bought from a discount machine tool supply for a reasonable price.
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
  • SWest
  • 10 22 2014
31 Dec 2014 16:58 #657485 by SWest
Different dealers will sell jets at decent prices. My local Yamaha dealer sold me pilot jets for $2.99 where the Kawasaki dealer wanted $12.99. I passed and gave them a bad review.
