Needle adjustment questions
Re: Needle adjustment questions
26 Jul 2015 19:53
There was a thread that said it wouldn't run right without them
26 Jul 2015 20:31
I'd put the plug back in. They are in there for a reason.
Regarding the needles, sometimes you can put washers under the clips to lift them a little. if those carbs have springs under the needle though the needle height is controlled by the spacer on top of the needle.
- loudhvx
27 Jul 2015 07:49
It sounds like you have not found a jetting formula for running pods on those CV carbs. If you can find one, that will eliminate a lot of trial and error, (like months of trial and error).
If this bike is new to you, and hasn't run properly yet, you can eliminate a lot of variables by going with the stock jetting and airbox first (as Ed was getting at). Then when it's running right, you can start on the long jetting process (very long, unless you can get info from someone who has already done it).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
27 Jul 2015 08:08
You might try jetsRus for adjustable needles for earlier years.
