Needle adjustment questions
  • j4k3
  • j4k3's Avatar Topic Author
21 Dec 2014 16:28
#656650
So I have an 83 kz650(h3 csr?), and from what I gathered the carbs are mikuni bs32. Why is it so hard to find bowl drain screws for these things?
While cleaning the carbs I noticed the diaphragm needle only has one notch. Is this normal? I'm guessing maybe I can buy an adjustable one along with larger jets?
Also, I know my main jet is the one in the center. But where is my pilot? Do I have to drill out a cover somewhere?
Attachment image_2014-12-22.jpg not found
Attachment image_2014-12-22-2.jpg not found
Attachment image_2014-12-22-3.jpg not found
83' KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Needle adjustment questions
21 Dec 2014 17:05
#656653
Those are CV carbs. They are preset. You might try jetsrus on line to see if there are compatible ones from a earlier year or years that will fit. They are good for altitude changes mileage and smog. Rejetting shouldn't be a issue unless you have a big bore kit and or high lift cam. The pilot should be next the main jet. Follow the passage way from the idle mixture screw to the float bowl. If you go to that site and they have yours listed you may be able to see what it looks like.
  • j4k3
21 Dec 2014 17:44
#656665
Alright, I didn't realize the cv carbs didn't have that adjustment. I'm running 4-1 exhaust and pod filters, so I can only assume I'm going to be a touch lean.
83' KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Dec 2014 18:15
#656667
There's carb kits. See if z1enterprizes has them. If not see if you ca get some jets. Maybe someone else has some suggestions.
  • j4k3
22 Dec 2014 11:36
#656722
Is the brass cap above the jet removable?
Attachment image_2014-12-22-4.jpg not found
I still can't find anywhere that sells the bowl drain screws I need. They're kind of long and tapered with an o-ring.
83' KZ650
22 Dec 2014 12:09
#656724
Pods on the CV carbs? Did your bike come with an airbox? Have you ridden the bike much yet? Ed
  • mopguy
  • mopguy's Avatar
22 Dec 2014 12:26 - 22 Dec 2014 12:34
#656725
Yes the brass cap is removable, and you will find the Pilot Jet in there, O rings on cap may need to be replaced if cap doe not go back in snug. You can buy bowl drain screws at siriusconinc.com.
Last edit: 22 Dec 2014 12:34 by mopguy. Reason: added
  • bountyhunter
  • bountyhunter's Avatar
22 Dec 2014 13:07
#656728
My 79 750 twin had adjustable needles (five slots) but later years with same carbs did not. I always assumed it was because of emission regulations.
  • j4k3
24 Dec 2014 06:01
#656868
Now, when I remove the brass cap, does it have to be replaced with a new one or does the original fit back in?
83' KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Dec 2014 07:02
#656871
I suspect it isn't needed. There should be a hole just above it, if so, it's there to prevent tampering just like the needles and mixture screws. Gotta love them liberals. Sure, I'll buy a grocery bag for ten cents that isn't worth two sheets of toilet paper just to make things better.
GIVE ME A BREAK
  • jackleberry
  • jackleberry's Avatar
26 Jul 2015 18:52
#682888
j4k3 wrote: Now, when I remove the brass cap, does it have to be replaced with a new one or does the original fit back in?
You don't have to replace the plug with a new one. Just replace the o-ring on it.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
26 Jul 2015 19:30
#682895
:unsure: Is the plug needed? The BS34's utilize plugs over the pilot jets too, and I often wonder the answer. They are a pita to deal with, but if not necessary to be there, I may choose to leave them out next time I jet...
1982 KZ1100-A2
