Needle adjustment questions
- j4k3
21 Dec 2014 16:28
So I have an 83 kz650(h3 csr?), and from what I gathered the carbs are mikuni bs32. Why is it so hard to find bowl drain screws for these things?
While cleaning the carbs I noticed the diaphragm needle only has one notch. Is this normal? I'm guessing maybe I can buy an adjustable one along with larger jets?
Also, I know my main jet is the one in the center. But where is my pilot? Do I have to drill out a cover somewhere?
Attachment image_2014-12-22.jpg not found
Attachment image_2014-12-22-2.jpg not found
Attachment image_2014-12-22-3.jpg not found
83' KZ650
Re: Needle adjustment questions
21 Dec 2014 17:05
Those are CV carbs. They are preset. You might try jetsrus on line to see if there are compatible ones from a earlier year or years that will fit. They are good for altitude changes mileage and smog. Rejetting shouldn't be a issue unless you have a big bore kit and or high lift cam. The pilot should be next the main jet. Follow the passage way from the idle mixture screw to the float bowl. If you go to that site and they have yours listed you may be able to see what it looks like.
- j4k3
21 Dec 2014 17:44
Alright, I didn't realize the cv carbs didn't have that adjustment. I'm running 4-1 exhaust and pod filters, so I can only assume I'm going to be a touch lean.
83' KZ650
21 Dec 2014 18:15
There's carb kits. See if z1enterprizes has them. If not see if you ca get some jets. Maybe someone else has some suggestions.
- j4k3
22 Dec 2014 11:36
Is the brass cap above the jet removable?
I still can't find anywhere that sells the bowl drain screws I need. They're kind of long and tapered with an o-ring.
Attachment image_2014-12-22-4.jpg not found
83' KZ650
22 Dec 2014 12:09
Pods on the CV carbs? Did your bike come with an airbox? Have you ridden the bike much yet? Ed
- mopguy
22 Dec 2014 12:26 - 22 Dec 2014 12:34
Yes the brass cap is removable, and you will find the Pilot Jet in there, O rings on cap may need to be replaced if cap doe not go back in snug. You can buy bowl drain screws at siriusconinc.com.
Last edit: 22 Dec 2014 12:34 by mopguy. Reason: added
- bountyhunter
22 Dec 2014 13:07
My 79 750 twin had adjustable needles (five slots) but later years with same carbs did not. I always assumed it was because of emission regulations.
- j4k3
24 Dec 2014 06:01
Now, when I remove the brass cap, does it have to be replaced with a new one or does the original fit back in?
83' KZ650
24 Dec 2014 07:02
I suspect it isn't needed. There should be a hole just above it, if so, it's there to prevent tampering just like the needles and mixture screws. Gotta love them liberals. Sure, I'll buy a grocery bag for ten cents that isn't worth two sheets of toilet paper just to make things better.
GIVE ME A BREAK
GIVE ME A BREAK
- jackleberry
26 Jul 2015 18:52j4k3 wrote: Now, when I remove the brass cap, does it have to be replaced with a new one or does the original fit back in?
You don't have to replace the plug with a new one. Just replace the o-ring on it.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- daveo
26 Jul 2015 19:30jackleberry wrote:j4k3 wrote: Now, when I remove the brass cap, does it have to be replaced with a new one or does the original fit back in?
1982 KZ1100-A2
