- Thank you received: 2098
Carb rack is over flowing
28 Nov 2013 16:05 - 28 Nov 2013 16:08 #614317
by Patton
If not already done, should change oil and filter before running the engine, or should say "before ruining the engine.
Replied by Patton on topic Carb rack is over flowing
e.dishong2 wrote: . . . got the gas leak issue fix. I got the bike started . . . have gas in my oil? . . . .
Last edit: 28 Nov 2013 16:08 by Patton.
- JR
- Thank you received: 449
28 Nov 2013 16:37 - 28 Nov 2013 16:38 #614321
by JR
In another post
www.kzrider.com/forum/2-engine/591938-wh...ice-points-to-adress
you mentioned possibly using PODS. Are you using the PODS? .... in which case you will need to change the carb jets to get enough gas to go with the increased air. Or are you using the old airbox and an air filter? The original airbox and filter may be a good way to start.
First you should do what Patton just suggested and change the contaminated oil
Sounds like you are making progress and learning at the same time.
Good luck
Replied by JR on topic Carb rack is over flowing
"....But it doesn't like to rev up. When I try to rev it up, I have to do it slowly or it will die, and even then it doesn't increases rpms smoothly. It will sputter and want to die....."
In another post
Good luck
Last edit: 28 Nov 2013 16:38 by JR.
- e.dishong2
28 Nov 2013 18:15 #614325
by e.dishong2
Replied by e.dishong2 on topic Carb rack is over flowing
I just finished breaking down the carbs, and cleaning them. There was a bunch of s*** in there. The air has to be my other issue. I am using the pods, I didn't know it would effect it that much. But now I might have a even bigger problem. I ran the bike for a good little bit "15 minutes" before I realized it has gas in the oil. I think I might of swelled my pistons rings. It started to turn over slowly, it may be the battery...... but it could also could be the motor.
- JR
28 Nov 2013 18:55 - 29 Nov 2013 06:48 #614329
by JR
If the bike was idling or running for 15 minutes without moving then it may have overheated causing it to stall. Worst case scenario = seized. These air cooled engines need airflow to keep cool
I would suggest you change the oil and try again tomorrow when the motor has cooled. Fingers crossed
Last edit: 29 Nov 2013 06:48 by JR. Reason: spelling
