Carb rack is over flowing
- e.dishong2
- Thank you received: 2098
Is an in-line fuel filter installed?
- e.dishong2
e.dishong2 wrote: . . . noticed on carb #1, the float vaule was not turned a little bit . . . .
float vaule was not turned a little bit -- Not sure what that means.
- Cynjut
- Thank you received: 26
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- e.dishong2
- JR
- Thank you received: 449
If the leak is between the carbs then you need to pin down where. Is it at the T junction in the fuel line when it enters the carbs or the little short fuel lines that connect the carbs together ? Or perhaps when you had the carbs apart you had problems getting the O ring # 11009 back in place on the float bowls. I am thinking that if the float valve #16030 was not seating correctly then the fuel would be coming out the overflow lines at the bottom of the carbs
- e.dishong2
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- e.dishong2
- bountyhunter
- Thank you received: 337
sounds like a vacuum leake.dishong2 wrote: Okay guys, I got the gas leak issue fix. I got the bike started, it seems to idle alright "I am not a bike mechanic by no means, I am very new to bikes and do not know everything I need to know about the motor/carbs" But it doesn't like to rev up. When I try to rev it up, I have to do it slowly or it will die, and even then it doesn't increases rpms smoothly. It will sputter and want to die. Then once it is at a higher rpm (2500-4000) it doesn't want to come back down right away.
- e.dishong2
