- Thank you received: 15
problem starting
- peavylotus
- Movin on up
1980 KZ 1045 LTD Currently Workin' It Out
- happyhunter
I will also need a good manual for this bike 82 KZ305CSR). Any recommendations?
What is this kit for tank cleaning from Yamaha? Is it tools or just special solvent? Seems to me fine dirt is always going to be there. Would not a filter be the answer? Or is rust so fine it passes thru?
Thanks,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
- dkoz
- Thank you received: 17
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
- dkoz
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
- happyhunter
i33.photobucket.com/albums/d96/happyhunt...4087_zps38fcf39d.jpg
i33.photobucket.com/albums/d96/happyhunt...4086_zpsc97728d4.jpg
I am looking at this thinking I may be able to remove and clean a lot of stuff without taking off the carbs. Is this correct? Are the pilot jets accessible thru the bottom? I am not too familiar with motor cycles yet,but I am wanting to learn.
Thanks,
HH
- Thank you received: 2098
Attachment picpostnewsite912x671.jpg not found
www.kaseydavis.com/1987KZ305LTD.pdf
- JR
- Thank you received: 449
happyhunter wrote: OK let me try to post a pict of the carbs....
Thanks,
HH
In the second picture it looks like there is some type of brown goo on the rubber boot between the Keihin carb and motor. Perhaps put thereby the PO as a sealer. Sealers in this area are a temporary fix at best. Also brown stains beneath the carb look like at least one carb was leaking or overflowing at one point. If you are going to clean the carbs it's best to do it thoroughly. To do this you really need to take them off and it's not to difficult.
Turn off the gas and disconnect the gas line. You may need to open the seat and remove a bolt before you can take off the gas tank. Loosen the hose clamps on the rubber boots and the air hoses, Fold the airbox hoses back or push them into the airbox. wiggle the carbs out a bit, disconnect the throttle cable from the carbs. pull the carbs out. The first time you do this it might take 20 minutes
A manual would really help you with the carb details on jets and what to look for.. I think there are articles in the Filebase here which could help.
Good luck
- dkoz
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
- happyhunter
When I drained it I put a paper towel in the funnel. I had about a gallon of gas in it that I drained over the towel. I did not see any dust or such.
Tomorrow I plan on removing and disassembling the carbs. I have a can of Gumout I picked up tonight. I have not done a carb since I was about 22 yrs old (now 46). This will be fun.
I want to put a fuel filter on it. The fuel line looks OK, no cracking, pretty flexible. I still may replace the line when I pick up the filter. I was going to use a cheap disposable filter from an auto parts store. Is this a good idea or should I get it at the motorcycle shop?
I do like to wrench on stuff... when it is not a primary vehicle that I need to use tomorrow. I do intend to ride this on decent days this winter. So I do want to get it together hopefully this weekend. If not I will drive the minivan.
Thanks to all for the help,
HH
- JR
An in line fuel filter is a great idea. Most people use them. If you can't get one from a motorcycle store use one for a lawn tractor. Be careful with ones from an auto parts store. Many auto fuel filters only work when the fuel is under pressure from a fuel pump and won't work on these old bikes.
- happyhunter
When I drained the tank I think there may have been some powder around the edges of the paper towel. When I first looked I was looking in the middle of the towel, like bottom center of the funnel, but the petcock was directing the stream to the side of the funnel.
I am still working on the rust in the tank. I have that Harbor Freight stuff in it. Been rotating it around all day, A few hours in each position. So far I do not see anything that is a big improvement. I will probably let it sit all weekend and put the tank back on Monday.
Anyway. It was a good day of productivity. Now other duties call.
Thanks,
HH
