hesitation off idle
  • megadub72
  • megadub72's Avatar Topic Author
hesitation off idle
16 Oct 2013 02:40
#610175
When I sit at a light, it idles just fine. When I get ready to go from the light, if I just go straight to throttle, it will die. If I tap the throttle first, then takeoff there is no problem. It is apparently a weak point, but I do not know if it is a needle position or a pilot jet problem. Has anyone dealt with this hesitation off idle? How did you fix it?
1979 KZ1000ST daily rider
Aftermarket Header 4-1
1980 KZ1300 project
Stock, so far
  • koolaid_kid
  • koolaid_kid's Avatar
Re: hesitation off idle
16 Oct 2013 08:42
#610185
Whatcha riding?
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • Cynjut
  • Cynjut's Avatar
16 Oct 2013 10:20
#610198
If this has just started happening, it sounds like a fuel limiting 'clog' in one of the jets. This might be a good test for some good carb or FI cleaner.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
16 Oct 2013 10:31
#610203
carb sync?
pilot screw adjustments?
Good Fortune! :)
  • megadub72
16 Oct 2013 11:24
#610217
It's a '79 KZ1000 ST. I just bought it a couple months ago, and it has always done the hesitation. The funny part is that I bought it from a dealer, and they had done a bunch of work to it, already. Clean carbs, new plugs, new wires, new stator, etc. But, I can tell from riding it for awhile, it needs some more work.
It idles very nicely, so I am guessing the pilot screw is pretty good. Maybe, I will need to invest in a carb syncer to see if they are off a little.
1980 KZ1300 project
Stock, so far
  • koolaid_kid
16 Oct 2013 11:39
#610222
Not sure what folk on this forum use, but on another forum the Morgan Carbtune is considered the gold standard. It's a one-time investment, and well worth it iMHO.
1983 GPz 750
16 Oct 2013 12:09 - 16 Oct 2013 12:41
#610225
megadub72 wrote: ... It idles very nicely, so I am guessing the pilot screw is pretty good....
More than just idle quality, the pilot screw regulates carb performance throughout the pilot circuit, including tuning for a strong smooth pull-away from idle.
Same for sync.
Would suspect that pilot circuit is either too rich or too lean, either of which could contribute to poor performance at pull-away from idle.
Of course, there are many possible conditions that might result in the reported issue, such as noted in the FSM:
Good Fortune! :)
Last edit: 16 Oct 2013 12:41 by Patton.
  • bemoore
  • bemoore's Avatar
16 Oct 2013 13:34
#610226
I had this problem when I had pods. When I re-installed the airbox, the problem improved quite a bit. I tweaked the air screws and was able to get the hesitation completely eliminated.
77 KZ650C1 w/Kerker 4-1
  • koolaid_kid
16 Oct 2013 15:37
#610242
Pods can be difficult to tune, to be sure. I used a wideband, so it made it much easier. Not everyone has access to one, unfortunately, and is forced to use the plug chop method.
1983 GPz 750
  • megadub72
16 Oct 2013 15:50
#610244
It has the standard airbox, but it does have an aftermarket header. I will adjust the pilot screws to be sure they are set correctly. We will go from there.
1980 KZ1300 project
Stock, so far
  • koolaid_kid
16 Oct 2013 15:56
#610246
With a header all you should need to do is increase the size of the main jets.
1983 GPz 750
16 Oct 2013 22:54
#610282
Any popping from the exhaust on deceleration?
If so, any such popping may indicate a too lean pilot circuit.
Good Fortune! :)
