Carb holder screws
- Rev
Carb holder screws
29 Aug 2013 23:10
:huh: When replacing the carb holders should you torque the screws to any particular value?
78 kz650, Maxi-dwell, Modified flow through air box, Dyna coils.
Re: Carb holder screws
29 Aug 2013 23:21
Excellent question! The Kawasaki Service Manual calls for the use of a non-permanent locking agent (like BLUE Loctite). It doesn’t specify torque for those screws separately, but since they are 6mm 1.0 pitch screws it calls for 4.5 – 6.5 ft. lbs. in the general torque table. Ed
- Rev
29 Aug 2013 23:27
Thanks Ed. I knew I could count on someone here to come up with a value.
- RonKZ650
29 Aug 2013 23:32
Not easy to use a torque wrench on a philips head screw. Main thing is hope and pray they are not seized in the head. These frequently will break off when trying to remove, then you are in deep trouble. I wouldn't worry about torque or using loctite. Getting them off is the main issue.
- Rev
29 Aug 2013 23:44
Screws came off with no problem and have switched over to allen head harden steel screws.
- MFolks
29 Aug 2013 23:47
Using SS in Aluminum can cause galling/seizing. I use a little of the silver Anti-seize on the first few threads. Makes for easier removal next time.
29 Aug 2013 23:59 - 30 Aug 2013 00:03
Deleted - question answered. Ed
Last edit: 30 Aug 2013 00:03 by 650ed.
- KZB2 650
31 Aug 2013 10:05 - 31 Aug 2013 10:07650ed wrote: Excellent question! The Kawasaki Service Manual calls for the use of a non-permanent locking agent (like BLUE Loctite). It doesn’t specify torque for those screws separately, but since they are 6mm 1.0 pitch screws it calls for 4.5 – 6.5 ft. lbs. in the general torque table. Ed
I remember a few months ago you jumping all over me for suggesting this and even gave you the page in the manual where it states it. Must a found it in the manual huh.
I went around 60 to 65 inch pounds on them so 5 to 5 and a half pounds sounds about right and felt nice and solid.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 31 Aug 2013 10:07 by KZB2 650.
- KZB2 650
31 Aug 2013 10:09RonKZ650 wrote: Not easy to use a torque wrench on a philips head screw. Main thing is hope and pray they are not seized in the head. These frequently will break off when trying to remove, then you are in deep trouble. I wouldn't worry about torque or using loctite. Getting them off is the main issue.
This why allen heads work so nice here.
1978 KZ650 b-2
31 Aug 2013 14:23 - 31 Aug 2013 14:30KZB2 650 wrote:650ed wrote: Excellent question! The Kawasaki Service Manual calls for the use of a non-permanent locking agent (like BLUE Loctite). It doesn’t specify torque for those screws separately, but since they are 6mm 1.0 pitch screws it calls for 4.5 – 6.5 ft. lbs. in the general torque table. Ed
I remember a few months ago you jumping all over me for suggesting this and even gave you the page in the manual where it states it. Must a found it in the manual huh....
Dude you are SO wrong it is not even funny! Where do you come up with this nonsense?
Here's the BS you recommended 3 months, 2 weeks ago:
"They recommend using blue lock tight on these in the manual. Plugs, valve cover bolts, side cover allens etc love anti sieze but not on these."
Notice you DID NOT EVEN MENTION carb holder screws! You were talking about a bunch of fasteners that according to the manual DO NOT get loctite. Loctite on the plugs? Really?? You do that?? Here's the link to your posting - try READING it - YOU wrote it!
kzrider.com/forum/3-carburetor/586732-kz...-and-sputters#587779
So YES. I jumped all over you for giving such rotten advice! It was rotten then and it is still rotten and I still stand by every word that I wrote! Here's what I stated:
"What - are you kidding??? The Kawasaki Service Manuals I have are VERY SPECIFIC about which fasteners get a locking agent (loctite) and those manuals DO NOT recommend using locktight of any type on any of the fasteners you listed - DON'T DO IT! That is really bad advice! What manual do you have that recommends using locktight on any of those fasteners??? Please show me the text. Ed"
Here's the link to my posting - try READING it!
kzrider.com/forum/3-carburetor/586732-kz...-and-sputters#587783
Maybe YOU need to find the manual and read it! I have already read mine. Ed
Last edit: 31 Aug 2013 14:30 by 650ed.
- KZB2 650
31 Aug 2013 23:18650ed wrote:KZB2 650 wrote:650ed wrote: Excellent question! The Kawasaki Service Manual calls for the use of a non-permanent locking agent (like BLUE Loctite). It doesn’t specify torque for those screws separately, but since they are 6mm 1.0 pitch screws it calls for 4.5 – 6.5 ft. lbs. in the general torque table. Ed
What the hell do you think I meant by these !!!!! since they were talking about carb holder screws getting anti sieze I pointed out the manual says blue locktite on them and not anti sieze. I then told you you mis understood and I ment anti sieze is fine on plugs, valve cover bolts etc but no the carb holder screws which should be locktited.
1978 KZ650 b-2
- 74ullc
31 Aug 2013 23:38
It's just a misunderstanding between you two guys. Since I have just had a few beers in rapid succession I will now be able to explain exactly what happened. :lol:
You wrote...
Ed read....
In the manual they recommend using blue lock tight on plugs, valve cover bolts, side cover allens, etc.
You meant....
They recommend using blue lock tight on carb holder screws in the manual. Plugs, valve cover bolts, side cover allens, ect love anti seize but not on carb holder bolts.
It was a little confusing the way it was written originally. The word "these" was referring to carb holder screws but it was vague.....or something like that. My High School English teacher could probably explain it better.
Speaking of High School English.....I had this teacher, I think junior year....some days she would wear a very short blue jean skirt. On those days and ONLY those days she would sit on her desk facing the class. What a wonderful woman! We must have been 15-16 yrs old....all us guys going nuts on those days! Looking back on it she knew EXACTLY what she was doing! Just like the car washing gal in "Cool Hand Luke". Time for another beer.....maybe I'll throw old Cool Hand in the Blu Ray...been too long.
You wrote...
Ed read....
You meant....
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
The following user(s) said Thank You: 650ed, KZB2 650
