KZ 1100 backfires and sputters
  • trojan
  • trojan's Avatar Topic Author
10 May 2013 13:07
#586732
So my KZ 1100 1981 is backfiring from the exhaust + carbs and sputters when cold. When warmed up runs great. Cabs were cleaned, synched, boots seem to be in good shape (sprayed starter fluid oround and nothing happened.
Seems like an air leak-but as far as i checked there is none...What could be the problem?
Thanks!!
Re: KZ 1100 backfires and sputters
10 May 2013 13:28
#586739
trojan wrote: So my KZ 1100 1981 is backfiring from the exhaust + carbs and sputters when cold. When warmed up runs great. Cabs were cleaned, synched, boots seem to be in good shape (sprayed starter fluid oround and nothing happened.
Thanks!!
Backfires through the carbs when cold, but not when warm?
Good Fortune! :)
  • trojan
10 May 2013 13:51 - 10 May 2013 14:01
#586744
Jup, just when cold-when the chocke is still on. I can hear popping or actually more of a puff-ing noise and sometimes even see gases being pushed through carburetor manifold.
Last edit: 10 May 2013 14:01 by trojan.
10 May 2013 14:25 - 10 May 2013 16:53
#586749
It sounds like you may not have properly tested for carb holder leaks. What was the idle set at when you tested? It is very important to temporarily set the idle as low as possible when testing - should be down well below 900 rpm as far as possible without stalling engine. This results in the slides being closed which in turn raises the vacuum level within the carb holders. Then spray carb cleaner around the mating surfaces between the carb holders and cylinder head and where the carbs join the holders. If there is a leak it should affect the idle and may stall the engine. Also check the little vacuum caps on the carb holders to make sure they're in good shape and tight. Give it a try - it's easy to do and may show a leak. Ed
Last edit: 10 May 2013 16:53 by 650ed.
  • trojan
11 May 2013 12:16
#586859
It was the boots!! Did as you said and tne engine stalled. Also found out that carb cleaner is way better for testing because start spray evaporates too quickly.
Thanks for the advice!!
11 May 2013 12:23
#586860
I'm glad it helped! Ed
11 May 2013 13:05
#586863
A word of advice on removing the old carb holders – The original carb holder screws can be extremely hard to remove from the cylinder head. Lots of folks have stripped the screw heads or broken the screws off in the cylinder head trying to remove them – they can be VERY stubborn! I had read about this problem before replacing my carb holders and decided not to take chances. I soaked the carb holder screws with Kano Kroil for 3 days before removing them and I used screwdriver bits I had modified to match the JIS screws. You may not be aware that the crosshead screws on the Kawasaki bikes are not Phillips even though they look like them. They are made to the Japanese Industrial Standard (JIS) and do not match up well at all with Phillips screwdrivers. They actually work MUCH better than Phillips screws because they are not designed to “cam out” so you can apply more pressure without stripping the heads, but you MUST use JIS bits or bits modified to fit the JIS screws or they will strip.
Having soaked mine for 3 days with Kroil and using a JIS type bit my carb holder screws came out very easily.
Kroil can be ordered directly from the manufacturer or can often be found at gun shows or some gun shops. I ordered mine online. This is what I use as shown on their order form: Kroil 1/2 pint (8 oz.) can - $9.25 ea. Here’s their link:
www.kanolabs.com/penLub.html
Regarding the JIS screwdriver bits – if you haven’t seen the thread below you may want to take a look at it as it describes how to modify Phillips bits to match JIS screws – it’s very easy to do and well worth the effort.
kzrider.com/forum/21-tools/532335-budget...ewdriver-tips#532335
Here’s what the Kroil can looks like. A half pint can will last forever; no need to buy a larger size. Ed
[IMG
  • Pindar
  • Pindar's Avatar
12 May 2013 11:24
#587001
Yes, I've just pulled them apart and had one of the carb holder screw head stripped...
(Had to file the head with metal saw and wedge a large flat head to get it off.)
I've replaced them all with black Allen (Hex) 6M x 16mm, and placed washers to pad the screws a little. Length of screw should be between 14mm and 16mm as far as I can tell.
Love the Allen screws. I'm trying to replace all engine screws to Allen as I go on. Not very authentic but mechanically awesome!
Cheers
12 May 2013 11:51
#587006
Just be careful not to overtighten the Allens and strip the threads in the aluminum engine. Ed
  • mopguy
  • mopguy's Avatar
15 May 2013 23:09
#587633
I used anticease on mine, hopefully it makes it easier for the next time.
  • KZB2 650
  • KZB2 650's Avatar
16 May 2013 16:28
#587779
mopguy wrote: I used anticease on mine, hopefully it makes it easier for the next time.
They recommend using blue lock tight on these in the manual. Plugs, valve cover bolts, side cover allens etc love anti sieze but not on these.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
16 May 2013 16:53 - 16 May 2013 17:35
#587783
What - are you kidding??? The Kawasaki Service Manuals I have are VERY SPECIFIC about which fasteners get a locking agent (loctite) and those manuals DO NOT recommend using locktight of any type on any of the fasteners you listed - DON'T DO IT! That is really bad advice!
What manual do you have that recommends using locktight on any of those fasteners??? Please show me the text.
Last edit: 16 May 2013 17:35 by 650ed.
The following user(s) said Thank You: Matteson
